Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 03-07-2007, 07:24 AM
01xr400r 01xr400r is offline
Question AUX switches
Gotta question for ya. How do you hook into the factory aux swithces on the dash? Also has anyone install a P.I.E. radio aux converter, it plugs into the aux port on the stock radio, it is an adapter that gives you rca plugs. Just wondering where you mounted yours and witch wire did you hook to for power?
Old 03-07-2007, 07:34 AM
teameyecatcher teameyecatcher is offline
Do you mean the 4 AUX switches next to the TBC? If so then look behind your pull-out panel under the steering wheel and there should be four orange wires labeled Aux-1 through 4. Those are power, so hook them up that way then ground out whatever accessory you have.
Old 03-07-2007, 07:53 AM
thanks those are the ones I was talking about
Old 03-07-2007, 11:33 AM
DKR DKR is offline
The Speedy Mod
You have to drop the fuse box to get to them easier....first two (1 & 2) are 30 amp and the second two (3&4) are 10 amp.
Old 03-07-2007, 12:20 PM
Fordinator Fordinator is offline
I have a P.I.E. converter in my rig. I can't remember what wire I tied into for the power to the converter though.
I do remember that I turned on the key and checked for 12 Volts on the radio connector with a Voltmeter. When I found a connection that was 12 Volts I turned the key off and opened the door to make sure that was the swicthed ignition wire.
I know the P.I.E. takes very little current so connecting it to the ignition wire will be fine, infact I supply power to my MP3 player with this same wire and have had no problems.
Oh and the sound from these things are great, if you have used a FM modulator you will throw it away afterwards. Also make sure you adjust the level on the converter before your put the dash back together!!!
Old 03-07-2007, 12:25 PM
thanks I'm going to be hooking it up this weekend I'll let you know how I like it
Old 03-12-2007, 04:27 AM
put the PIE converter in last weekend it sounds great. I mounted the box in the ashtry/compartment thingy for easy access
Old 03-12-2007, 04:39 AM
Rescuediver Rescuediver is offline
SMOKE ROLLER
How big is that thing?? Got Pic's?? Is that the converter to use the factory AUX button on the radio for Sat. radio or TV/DVD's??
Old 03-12-2007, 05:24 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
just wondering if someone makes those switches for my 03... i know ive seen them somewhere but cant find them anymore... that lil space is useless to me so i would love to find something that can fit in there to put some aux switches.... thanks
-Raul
Old 03-12-2007, 06:37 AM
BigGreen06 BigGreen06 is offline
<b>Premium Member</b>
I know anyone can buy the ones for the 05/06 years, but you might have to create a custom housing in the dash for it.
-BG06.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
