Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 10-04-2009, 06:19 PM
njmudrat njmudrat is offline
dome light
I have an 05 f350..When I open up my driver side door the dome light does not go on.I can turn it on when I hit the switch on the side of the light and it will NOT go on when I use the dimmer knob on the dash..What can it be,,,thx for any help
Old 10-13-2009, 04:48 AM
anybody have an idea?
Old 10-13-2009, 04:53 AM
Dallas4x4 Dallas4x4 is offline
Is it just one door where it doesnt turn on when you open it?
Old 10-13-2009, 05:28 AM
gullagej gullagej is offline
Send a message via AIM to gullagej
It sounds like the door switch. Do the other functions (headlight on/ key in ignition chimes) activated by the door switch still work?
Old 10-13-2009, 06:53 PM
I have a supercab,but when I open driver or passenger door no light comes on..No head light but I don't think it ever came on when I opened door.The key ignition does chime....
Old 10-14-2009, 06:00 PM
uncertain uncertain is offline
I was having issues with my expy. Are the switches on this the same integrated stuff? Someone told me to spray them all with WD-40. I laughed and thought he was nuts. Well, after several other attempts, I figured what the heck. No issues in 6 months. give it a shot, can't hurt.
Old 10-14-2009, 06:41 PM
I don't want to sound stupid but what is an expy?
Old 10-14-2009, 09:45 PM
mdub707 mdub707 is offline
expedition.
The switches in the doors stick in the Fords, my rangers always did this too, spray the latch with WD-40, open and close the door about 10x, the light should work fine after that.
also njmudrat, the switch up on the dome light operates the two side lights, the light in the middle is the one that comes on when you open the doors, pull the clear plastic cover and make sure there is even a bulb in there.
I had this issue in one ranger as well, it came with no bulbs. I plugged the bulb in and it stayed on all the time, sprayed the latches with WD and it went away. Sometimes instead of fixing the issues, people will just remove the bulb because they dont know any better.
Step 1) make sure bulb is in place and good
step 2) spray door latches with WD
step 3) enjoy.
Its such a small issue, but man is it soooo nice to have!
Old 10-14-2009, 09:56 PM
Jake Jake is offline
<-----GTP38R
Maybe the bulb is burnt out.
Old 10-15-2009, 02:08 PM
mdub707 you were right!.I did not know there was a center bulb.I took the cover off and changed the bulb and now I have light...thx for all the help guys,this place is great !!!
