- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Ok I give up I need help with the factory switches
I have a 07 with the factory switches on the dash for accessories. Here is what i am doing. I put a dvd player in the dash and I need a switched source to simulate the parking brake. I would like to use the factory toggle switch....but I am not sure how they are wired. I basically need a switch wired to ground that can be turned off and on.
Can anyone shead some light???? Thanks |
| Sponsored Links |
I assume you need to simulate the parking brake to get around the built in safety to prevent the driver from watching movies while the vehicle is moving. If this is the case, why couldn't you just permanently ground that wire? If you absolutely need the switch, you need to find the power wire to your upfitter switch, cut it and make it a ground instead. That should get the job done. |
Thats what I need to do....Thats what i needed to know. The switch gets 12 volts. I need to re-configure the switch wire from power to ground.
For those who said to Just ground the wire...I cant do that the system is too smart!! thanks |
| Sponsored Links |
