Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 07-01-2009, 07:41 PM
kingranch89 kingranch89 is online now
A/C Help Please
my ac still blows an its cold but it will only blow threw the defroster on the windshield does anyone know the problem an its a 07 250 king ranch with the digital ac
Old 07-01-2009, 07:48 PM
jcs jcs is offline
Sounds like a vaccuum leak or the electric vaccuum pump isnt working
Old 07-01-2009, 07:49 PM
what does that take to fix
Old 07-01-2009, 07:54 PM
jcs jcs is offline
If its just a vaccuum leak its a matter of finding it could be under the dash or in the engine compartment the heater vents and auto locking hubs operate on vaccuum
Old 07-01-2009, 07:59 PM
i dont have auto locking hubs how much you think this would cost from ford
Old 07-01-2009, 08:05 PM
jcs jcs is offline
I couldn't say but its probably about a 100 bucks an hour for labor. I would look around under the dash and what not for a broken or unplugged vaccuum line first it may be something obvious
Old 07-02-2009, 01:15 PM
ford said the problem is the vaccum pump is not turning on........do i need a new one? ford did not have time to figure out the problem they cant look at it til monday
Old 07-10-2009, 02:03 PM
swilson143 swilson143 is offline
I have the exact same symptom. Worked fine this morning and now it only blows out the defrost vents.
I'll start looking for vacuum lines under the dash jcs... but do you know where the vacuum pump is located?
Thanks!
Old 07-10-2009, 02:05 PM
it right in front of ur passenger side battery i had to replace mine it was 200 bucks from ford but u can get them off the internet for around 100 they are really easy to replace i almost guarantee your vaccum pump went bad also it is very common in our trucks
Old 07-10-2009, 02:07 PM
kingranch89, here is another thread dealing with the same problem...
AIR CONDITIONING
I'm headed out to find this vacuum line now.
