- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Sirius Radio Install
I just got a Sirius Sporster 4 for my b-day. The FM extender antenna doesn't work like its cracked up to. How hard to wire directly to my radio (with 6 disc changer) and what all do i need and how much will it cost. Its an 06 F-250 Powerstroke
| Sponsored Links |
If you want to use the built in FM modulator, install the antenna(magnet mount on the roof) as close to the Stereo antenna as possible. (Read, top of cab, just above the glass on the passenger side.) The FM Modulator sends the signal from the actual unit, back through the recieve antenna and broadcasts a signal at a very low wattage to be recieved by your stock antenna. (Does that make sense???)
Problem with this scenario is that the only way you can hook up these Sirius receivers is through the FM modulator. The one inside these units is cheap and produces a very weak signal. You can pick up an exterior FM modulator from Best Buy for about $30. Installation is easy, you just pull apart your dash, pull out your head unit, unplug the antenna lead, insert the modulator antenna lead in the head unit and insert the antenna lead into the modulator. Then button everything back up. Your modulator has another lead that plugs directly into your Sportster receiver. If you want true integration (and much better quality), you need to purchase the $99 receiver, which usually requires installation by a professional, similar to what BigGreen did.
On another note, the satellite antenna on the roof has nothing to do with the modulation signal from the Sirius unit. It doesn't matter how close you put it to the stereo antenna, it won't improve your reception. |
| Sponsored Links |
