Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 06-27-2009, 02:34 PM
youngstroker youngstroker is offline
want to pump up the base
i work at a Mazda dealer and the fully loaded cx9 come with Bose audio system and when u turn it all the way it sounds crystal clear and i want that in my super duty but when it comes audio systems i don't even know where to start i want to replace the door speakers and add a sub woofer but i don't know what it means when they start talking about bridging and voice coils and rms or how to match sub woofer to amp and then adding a cap not sure who makes good products, can i still use my stock radio or do i have to buy and aftermarket one, i would like to know what set ups you guys are running, i am not looking for someone to spend a hour typing up what all that stuff means but if you could point me in the right direction so i can teach myself about it that would be very helpful.
Old 06-27-2009, 03:23 PM
05_PSD_Erik 05_PSD_Erik is offline
<---- That's My Kid!!!
check out Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers, wealth of information on car audio
HOWEVER, your best bet is going to be find a local car stereo shop and at least go talk to them about what you want to do. at least to get a good idea of what you need to do.
also, you do not HAVE to change your factory radio to run amps and the like, however, alot of people do change them out as an aftermarket head unit will allow easier adjustment and tuning for your system.
Old 06-27-2009, 03:47 PM
jamstoyz jamstoyz is offline
anything over stock is much better for sound. i run a alpine head unit, jl audio 1000.1 amp, two alpine type r 12", and kenwood dorr speakers up front and jbl's in the rear. all of it was used equipment and didnt cost much if you wire it yourself.
Old 06-27-2009, 04:22 PM
JSchuricht JSchuricht is offline
I would highly recommend an aftermarket HU as it will have the pre-amp connection needed to connect to a amp. You can use the stock HU with a hi-lo converter, but there is a moderate decrease in sound quality.
If you are thinking of doing the system yourself, check eBay. I picked up all my Alpine gear that way and saved a fortune.
Bridging= tying two amps or two amp channels together for more power
Voice coil= electromagnet in speaker that moves the speaker cone in relation to its magnet
RMS= Root Mean Square or basically the usable wattage/power of a amp
More definitions here.
Old 06-29-2009, 10:02 PM
i also want to upgrade the head unit with a double din flat screen, but i can't find anyone who makes one that fits my truck, what dose it take to modify one in there and witch one should i go with? thank for directing me to crutch fields web site it cleared up so much stuff i was confused on.
Old 06-30-2009, 07:01 AM
Just check around on Crutchfield and other car audio sites, there are a few guys on here running double-din HUs one of them will chime in hopefully!
Old 07-18-2009, 09:10 PM
semmens21 semmens21 is offline
i have a single din dvd player in my truck by a double din alpine or kenwood would fit with a mounting kit which you could get at almost any car audio shop.
