- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Amp has no power ideas ?
Its a 1200 watt boss amp all fuses are good it was just working fine, turn off the truck 2 hours later no power on the amp.
Like I said all fuses and connections are good that are visible is there one on the inside of the amp ? ![]() Any info would help , Thanks |
| Sponsored Links |
If you have a test light or a voltmeter check for power at the end of the red wire which should be like 4gauge wire with that amp, then check for power at your power cable that turns your amp on from your deck. Then check your ground wire by placing the red lead to your 4gauge wire and the black lead to your ground. If your amp is getting power from the main power line and from your deck wire and your ground is still good, then your amp is bad.
Thanks guys for the help and info !!! Had it check out with a voltmeter and all is good going to the amp fuses are good . My setup is factory radio with 2 10's the amp with a knob that adjust how much bass I want. That knob has a light on it which is out as well , the amp power light is off as well . I'm going to check and see if it has internal fuse if not then it's a goner lol doesn't smell burnt ... ![]() also there's no reset on the fuse that is a huge one at that // |
check the Line out converter. if its ok probably the amp. im getting alot of amps saturday. let me know what you looking for. i get really good deals on name brand stuff!!!
| Sponsored Links |
