Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 05-04-2009, 06:58 AM
EHBuckmaster EHBuckmaster is offline
Tranny temp pegged
Tranny temp on factory guage pegged to hot, check gauge lamp is on, and tow/haul light flashing. I checked fluid and it is just warm to touch. From reading past questions, i believe i have a tranny temp sender that needs replaced. My question is where is it located? Do you have to drop the pan? any help would be great...
Old 05-04-2009, 01:14 PM
should have posted that it is a 03 6.0 with torqueshift tranny..
Old 05-04-2009, 01:16 PM
symbols symbols is offline
Nonsense specialist
I'm pretty sure it's internal but heres a bump for someone who knows
Old 05-04-2009, 01:19 PM
blowinsmoke7.3 blowinsmoke7.3 is offline
Not sure myself either. The factory gauges are highly inaccurate. I recomend getting an aftermarket tranny temp gauge.
Old 05-06-2009, 10:32 AM
motoxracer42 motoxracer42 is offline
my friend took his in for a problem like that. a sensor went bad and his stock guage would do that. wow and i just read the rest of your post lol. my bad. im not exactly sure where the temp sensor is. on some trannys they are on the valve body but i havent looked at a 5r110. i guess this is just a bump.
Old 05-11-2009, 12:56 PM
Just an update for anyone that is looking for the same info.. You have to drop the pan to get to sensor...Very easy replacement.. My fluid was flushed and replaced less than 10k before, so i reused it.. changed the filter as long as the pan was off... Total cost was about 130 bucks... Sensor was 79, filter 44 from Ford.... Problem is gone...
Old 05-11-2009, 03:57 PM
scotty2280 scotty2280 is online now
glad you got her fixed
Old 05-20-2009, 05:15 PM
wolfpacldr wolfpacldr is offline
have this same problem. Ford said i needed to replace the sensor and the harness. 200.00 + bucks for the parts at Ford. where did you get your parts from?
Old 10-03-2009, 06:48 PM
sdigrazia1 sdigrazia1 is offline
I had the exact same problem as Buck. Dropped the pan and replaced the sensor (super easy fix). $79 for the sensor, changed the fluid and filter while I was in there for a grand total of $200. No more issues...knock on wood!
Old 10-27-2009, 05:14 PM
yosh30 yosh30 is offline
same issues here, can someone take a picture of the sender? so i know exactly what to change?
