Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
Old 02-16-2009, 11:55 AM
03-blue-Powerstroke 03-blue-Powerstroke is offline
Almost Deer Season!
External Trans Filter
About 10,000 miles ago I changed the interal and external transmission filters in my truck. So today I went back to change the external again but it is extremely tight. I tried using a breaker bar and then carefully an impact wrench but it still won't budge. Any ideas what to do?
Old 02-16-2009, 12:22 PM
BryanH BryanH is offline
You only need to do a little more than hand tight. Just for future reference. There is no need to torque it down that much. It is cast aluminum, Be careful removing it. I would tap around the outside of the o-ring a bit. that might help.
Good luck
Old 02-16-2009, 12:23 PM
Edit SORRY. I thought I read you USED a breaker bar to tighten it the first time
Old 02-16-2009, 12:29 PM
Tony V Tony V is offline
Sweet Diesel Smell
Spray it let it sit and try again later.
Old 02-16-2009, 12:31 PM
bigbaldbob bigbaldbob is offline
BIGGER breaker bar. Good luck.
Old 02-16-2009, 12:32 PM
Almost Deer Season!
I SOAKED it in PB Blaster and have had no luck, I guess Ill go soak it again and try later.
Old 02-16-2009, 12:34 PM
Almost Deer Season!
I had my friend hold the casting and I had a breaker bar with a four foot pipe and it wouldn't budge. I don't know how it got so tight because I only hand tightened it.
Old 02-16-2009, 12:35 PM
Actually I have used a heating torch to help loosen some things. Double check with someone smarter than me before you try that.
Old 02-16-2009, 12:36 PM
You can also try using a hammer to hit your wrenh. somtimes the jarring action of a hammer blow will loosen stuburn objects.
Old 02-16-2009, 12:39 PM
Almost Deer Season!
I hit it with spray a few minutes ago again so Ill go see if anything else works. Thanks for ideas!
