Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
  #11 (permalink)
Old 02-16-2009, 12:49 PM
Tony V Tony V is offline
Sweet Diesel Smell
wow it must be rusted in there somehow.
  #12 (permalink)
Old 02-16-2009, 01:36 PM
BigRobRN BigRobRN is offline
sheez, I can't imagine it being that tight if you only hand tightened it.
maybe spray some kano kroil on the seal?
  #13 (permalink)
Old 02-16-2009, 01:43 PM
BryanH BryanH is offline
Start the truck and let it warm up, THen see if it breaks loose.
  #14 (permalink)
Old 02-16-2009, 02:06 PM
03-blue-Powerstroke 03-blue-Powerstroke is offline
Almost Deer Season!
I got it off! I sprayed it again with blaster for the fifth time. Then I put my breaker bar on and had my brother hit it with a hammer. I don't know how it got that tight. There was no dirt or rust around the canister lip either. While I was under there I drained the fuel filter housing too.
  #15 (permalink)
Old 02-16-2009, 02:14 PM
bigbaldbob bigbaldbob is offline
Congratulations. Just dont forget to lube the Oring.
  #16 (permalink)
Old 02-17-2009, 08:31 AM
Mudracer80 Mudracer80 is offline
I cant get mine to break loose either, I actually broke a large chunk of the nut off the bottom and gave up after that. I dont want to break it anymore and have it leak.
I guess I might have to go buy a new one somewere. If I do then I will be coating the threads with anti seize before screwing the case on.
  #17 (permalink)
Old 02-17-2009, 08:57 AM
6.0 paul 6.0 paul is offline
Sometimes the aluminum will gum up with the salt, rain and road grime. I have had to use the acid rim cleaner to loosen things like that. It is nasty and DO NOT GET IN YOUR EYES. But it will eat the corrosion away and loosen it up.
  #18 (permalink)
Old 02-18-2009, 01:46 PM
Almost Deer Season!
I did the same thing to mine. Hoperfully it won't stick this time!
  #19 (permalink)
Old 02-18-2009, 02:35 PM
does anyone know if older model F250's have the same kind of filter housings? Say around 99-02 year models
  #20 (permalink)
Old 03-04-2009, 02:53 AM
ipz2222 ipz2222 is offline
External filter only used on the 5r110w/torqueshift. Late o3 up.
