What do you guys think? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-04-2014, 05:30 AM Thread Starter
Had my 06 in to the shop for a dropped valve, ended up messing the piston up too, so they had the cab off and motor out. They decided to split the motor and tranny and put new valves in the motor as well… Long story short, I picked it up yesterday, and it was running great, got about 10 miles away from the shop and I was leaving a gas station parking lot, it felt like it slipped out of gear for a second or to, then slammed back in… When shifting it into drive and reverse I did notice it was hard to move the lever also… It doesn't do this all of the time, but it will do it within 10 or fifteen minutes of driving. It also feels like its shifting through the gears differently… just not smooth, sometimes hard, sometimes at weird points. No clue whats going on, what do you guys think? Never had a shifting issue what so ever before this… It has to do with something that happened at the shop, right?
Thanks for any thoughts
2006 F350 CCLB SRW
Mods: ARP Studs, OEM Headgaskets, EGR Delete, Replaced Oil Cooler, Blue Spring Update, Updated Standpipes and Dummy Plugs, Cleaned Turbo.
ankern is offline
post #2 of 4 Old 05-04-2014, 11:05 AM
midnite rider's Avatar
Quoted: 285 Post(s)
is the fluid level correct. may of lost some in the r&r and wasn`t replaced ?
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #3 of 4 Old 05-04-2014, 04:16 PM Thread Starter
Got it back up to the shop…yeah on a sunday! pretty good guy. Anyways, put the computer on it, turns out its one of the solenoids, I think it was D?? can't remember specifically, but either way, just glad to hear my tranny isn't on the way out! Should have it back by the weekend.
2006 F350 CCLB SRW
ankern is offline
post #4 of 4 Old 05-17-2014, 09:28 AM Thread Starter
Okay, any help is appreciated here... Put the new solenoid in at the shop, transmission was still slipping and delaying. So shop says the next step is the torque converter... replaced that, and all was going well, I drove it home and it was good (flared slightly on the 3-5 shift)... Drove it around the next morning, and got on it a little just before home, when it went to shift, the motor bogged for a couple seconds then shut off on me. I was able to coast into my driveway. Batteries were completely dead, charged them up, got it to start...It wont move! Acts like it is in neutral in Drive, 1, 2, 3, and reverse. Also the throttle acts like it is unhooked when it is in reverse. Also my batteries keep dying on me. Any thoughts???? I am lost. Tow haul light did not flash at all... Any help is greatly appreciated.
2006 F350 CCLB SRW
ankern is offline
