How to R&R trans lines? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-03-2014, 03:03 PM Thread Starter
I am trying to replace the transmission lines on my '03. They're the ones that go from the transmission to the inline filter. I ended up cutting the old ones to get them out. Now I can't find a way to install the new ones. Any tips????
SOLD--2003 F-250 RC/LB FX4, 6.0, 5R110, EGR cooler capped off at both ends, CAT EC-1, Rotella T6, Motorcraft fuel and oil filters, Amsoil in diffs/T-case, blue spring update, ScanGuage II, 5" Diamond Eye exhaust (not cat, no muffler
) 4" downpipe, Cooper Discoverer S/T's (LT265/75R16E).
rlu_tech is offline
post #2 of 5 Old 05-03-2014, 03:44 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
honestly I haven't figured it out either. The last set I did I had to unbolt the motor mounts from the cradle and jack the engine up in the air for enough room to slide the new ones in.
I use a bottle jack (like your spare jack) underneath the bellhousing using a short 4x4 piece of wood to help spread the load. Be careful and good luck.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 5 Old 05-03-2014, 04:55 PM Thread Starter
Okay I'll have to try that. I'm guessing it shouldn't take to much lift to make some extra clearance. Trans lines are never fun, but I never had an expieriance this awful with them.
rlu_tech is offline
post #4 of 5 Old 05-03-2014, 05:30 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
No, surprisingly the engine lifts quite easily with the spare bottle jack. Don't over do it, just try a little at a time until the lines can slide in.
On a related note I do oil pans the same way.
-Matt
2015 F-250 XLT 6.7L
post #5 of 5 Old 05-03-2014, 05:45 PM Thread Starter
Oil pans too!!! I woulda never thought there'd be enough room to squeeze a pan out with the engine in the truck. Thanks for your help, I'm gonna give it another shot tomorrow.
rlu_tech is offline
