Won't shift in tow/haul - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-30-2014, 06:20 AM Thread Starter
For some reason my truck will not shift out of 1st in tow unless u hold it tip 3800 rpms which I don't like to do! It does the same thing with or without my sct x4 any ideas? With tow off it shifts just fine
jjyfz is offline
post #2 of 17 Old 05-04-2014, 05:18 PM Thread Starter
Wow no one?
jjyfz is offline
post #3 of 17 Old 05-11-2014, 05:42 PM
I had the same thing happen last spring with mine. I was towing my camper, stopped to look at a map and when I started back out, it wouldn't shift. I had to stop, turn off the truck and start again. I fixed the problem, but a year later, I'm starting to have more of the same even out of tow/haul. I'm not sure what it was, but I'm probably going to be getting my tranny redone here pretty soon.
davebow is offline
post #4 of 17 Old 05-12-2014, 05:18 AM Thread Starter
I'm thinking maybe a sensor or the program because the trans dosent slip or anything!
jjyfz is offline
post #5 of 17 Old 05-12-2014, 05:20 AM
shenanigans
junior125's Avatar
Quoted: 1622 Post(s)
Garage
disconnect your batteries, then turn your headlights on then turn the headlights off and reconnect your batteries, force the trans to re-learn
Mike
2005 CCSB F250 4X4
junior125 is online now
post #6 of 17 Old 05-17-2014, 12:57 PM Thread Starter
Did that and still the same thing
jjyfz is offline
post #7 of 17 Old 05-25-2014, 06:46 PM Thread Starter
Wow does not a single person have a clue??
jjyfz is offline
post #8 of 17 Old 05-25-2014, 06:52 PM
shenanigans
junior125's Avatar
Garage
know anyone that has a snap on scanner, IDS or auto engenuity?
Mike
2005 CCSB F250 4X4
post #9 of 17 Old 05-26-2014, 06:42 AM Thread Starter
What would I be looking for if I find one? Me and a guy used to work on cars together and he had one not sure if he still does or not.
jjyfz is offline
post #10 of 17 Old 05-26-2014, 06:50 AM
shenanigans
junior125's Avatar
Garage
transmission codes, transmission codes can't be found with a standard OBDII code reader
Mike
2005 CCSB F250 4X4
