huge pop and broke parts..... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-29-2014, 03:08 PM Thread Starter
Thumbs down huge pop and broke parts.....
Was driving home from good Friday going 70mph. Heard a huge pop. Thought I popped a tired got out all tires fine. Starting to go again and the truck is just rattling and vibrating. So I stopped again. Looking for tires mis spinning. So I got towed home. Hopped under the truck and saw my middle front universal was missing the pin bearing caps or whatever they're called. Got that changed out.... Then noticed this.. it looks like it where the transmission and transfer case connect. Pics momentarily. Can't get them posted from phone. big problem or quick fix.
santino_saiz is offline
post #2 of 4 Old 04-29-2014, 03:22 PM Thread Starter
sorry 2006 f250. all stock. 35s. just broke 149,000
Pics..
ID:	280202   Click image for larger version
ID:	280210   Click image for larger version
post #3 of 4 Old 04-29-2014, 04:04 PM
sbluke55's Avatar
Quoted: 589 Post(s)
Garage
Ouch. That's your tail housing for your tranny. I believe you can unbolt the broken one and bolt back in a new one. Check your seals on your tranny and t case. Check your output shaft on tranny and input shaft on the t case for damage. I would get a new tranny mount while your in there.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
santino_saiz (04-29-2014)
post #4 of 4 Old 04-29-2014, 05:13 PM Thread Starter
Thank you for your speedy response.
