Trans Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-27-2014, 07:08 PM Thread Starter
Exclamation Trans Help
Hello all well heres my story for today!
As i was getting onto the highway i hit the gas to merge and the truck would not move was around 3000 rpms but if i barely touch the gas the truck will would but it like bucks around. would this mean my trans is going? Is it a sensor possibly? any input would help thanks
HunkerJunker is offline
post #2 of 8 Old 04-27-2014, 07:17 PM
Term3's Avatar
Is your Tow/Haul light blinking?
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 8 Old 04-27-2014, 07:29 PM Thread Starter
nope no lights at all
post #4 of 8 Old 04-27-2014, 07:30 PM
Term3's Avatar
Check ATF level with it a normal operating temperature.
Term3 is offline
post #5 of 8 Old 04-27-2014, 08:08 PM Thread Starter
its full and nice and pink
post #6 of 8 Old 04-28-2014, 06:25 AM
shughey00's Avatar
Quoted: 35 Post(s)
Had a similar thing happen on my Ford Ranger a few years back......although it was not a Super Duty...obviously.
Would not move under hard acceleration....only could get it to crawl with low accelration and then it would buck and kick like the tranny was slipping then catching.
I thought geez man...can't afford a tranny. Turned out to be a speed sensor on one of the wheels. Even though they seem to be related to the ABS system they affect the tranny also...maybe in when and how to shift. So....under $200.00 later all was good.
Never had any lights on..no ABS...no blinking CEL which I think the f-150 gets with a tranny issue.
So...just saying....if it was fine one day and then the next day all of a sudden feels like a tranny failure and you literally did nothing from one day to the next...think possible sensor or solenoid.
Every modern vehicle with ABS brakes has some sort of speed sensor and dang things cause odd issues when they fail....the three I have had go always showed up like tranny issues. Only once did I get any kind of a warning light.
Had em f go on the ford....my sons Sentra and this past winter on my Sonata. The Ranger I described. The Sentra would not shift above 2nd gear and the Sonata, since it was a 2011, the computer fail safed to only 30 MPH or less and was the only one of the three vehcles with a warning light on and that was a traction control light.
So...just saying....weird stuff when they fail.
" border="0" />Professing themselves to be wise, they became fools
2006 F350 4x4 FX4 CCDRW, 4.30 gears, Edge CTS, Edge EAS EGT, 19.5 Rims, Blue Spring, Riff Raff hot side boots, Zerex CAt-1, IPR coolant filter, Ecm rollback and FICM Atlas 40 PHP, DC 185 alternator, Rancho RS7000MT, Ranch 9000 on the rear, 08 tranny pan and filter, heavy duty IPR EGR cooler...that now has been plugged off.
shughey00 is offline
post #7 of 8 Old 04-28-2014, 08:06 AM Thread Starter
ok ya im gunna get a code scanner and see if it picks up anything cuz as my self i dont have money for a tranny right now
post #8 of 8 Old 11-13-2015, 01:16 PM
Did you ever get it fixed?
A-A-Ron is offline
