Overdrive vibration from 45 to 55 or so - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-14-2014, 06:01 PM Thread Starter
marjamar's Avatar
My 04 F350 is giving a vibration when in overdrive from 45 to 55 or there abouts. I had this problem once before in a safari van. Had to replace the overdrive unit on the end of the transmission. I suppose I will read up on the transmission in this truck, but thought I'd just ask if anyone else has had and fixed this in their truck.
-Rodger
marjamar is offline
post #2 of 3 Old 05-03-2014, 03:44 PM
a.russ0311's Avatar
mine just started doing this today but not when in overdrive. when it starts to vibrate i put mine into over drive and it goes away.
a.russ0311 is offline
post #3 of 3 Old 06-25-2014, 07:50 PM
CIB03's Avatar
Wondering what you found out. I have a 04 250 that does this when not completely warmed up. It will shake at about 50 and if I let up then accelerate it down shifts and stops shaking. I was wondering if it has to do with torque converter. I am going to change fluid and see if that changes anything.
CIB03 is offline
