Trans slip and bump **** - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-08-2014, 07:45 AM Thread Starter
Powerstroke Tech
whitestrikr21's Avatar
Quoted: 3 Post(s)
Garage
I have a 03 f350 6.0 with innovative extreme street tune. When I start the truck up in the am I will get a few harsh shifts after it feeling like the trans isn't engaging a gear. This only happens when the trans fluid temp is under 60 degrees, with the tune in and first couple of shifts. This will not happen when I remove the tune trans shifts fine no matter what trans fluid temp is. Also when the tune is in the p1000 will not clear.It sets code for a speed sensor and friction material d. (don't remember exactly will update with that once I get to the truck) Has anyone had similar issues iam starting to think its something with the tune.
03 F-350 Crew Cab short bed
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
Silverline staintless turbo back 4"
XDP egr delete
whitestrikr21 is offline
post #2 of 4 Old 04-08-2014, 10:02 AM Thread Starter
Powerstroke Tech
Quoted: 3 Post(s)
Garage
P0730 incorrect gear ratio- gear control malfunction
P2703 transmission friction element d apply time range or performance
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
XDP egr delete
post #3 of 4 Old 04-08-2014, 11:28 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
It sounds like a corrupt tune.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 04-08-2014, 05:02 PM
4506.0's Avatar
Tune is timing the shifts wrong, or over pressurizing to soon.
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
