Vibration and humming in low gear - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-05-2014, 08:25 PM Thread Starter
jjvizinat's Avatar
So about 3 weeks ago I started getting a low humming or vibrating noise coming from under my center console where the transmission would be. Its only in the low gears and goes away when I get on it. Havent expirienced slipping and truck runs fine. Gonna get it checked out monday. Anybody got any ideas?
2006 F-250 King Ranch
Headstuds, OEM gaskets, Updated Oil Cooler, Stand Pipes, Dummy Plugs, STC Fitting (Trucks Unlimited, NC)
35" Toyo Open Country M/T
Coolant Filter with ELC Coolant
Blue Fuel Spring Upgrade
S&B Cold Air Intake
EGR Delete
SCT X4
Nice and clean
jjvizinat is offline
post #2 of 4 Old 05-13-2014, 08:33 PM
I noticed the same problem a few weeks ago, havent found any "for sure" or solid information on it yet and now its slowly getting louder and more noticeable in 5th gear. Have you found out whats wrong with it yet or do you have any links that could help me?
Thanks lots!
Mulleton is offline
post #3 of 4 Old 05-13-2014, 08:38 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
possibly u joint or carrier bearing the fact that it goes away when you jump on it almost has me positive on the one or the other.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 4 Old 05-14-2014, 10:44 AM Thread Starter
jjvizinat's Avatar
Never found out "for sure" what it was and still haven't taken it anywhere. Still have vibration but it seems to have quieted down a bit. Or it could just me getting used to it.
S&B Cold Air Intake
EGR Delete
SCT X4
Nice and clean
