New Alternator, Now Tranny Slipping? WTF? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-04-2014, 10:10 AM Thread Starter
Angry New Alternator, Now Tranny Slipping? WTF?
Put a new alternator on my truck after getting a new FICM with the php80 tune on it. The alternator is a 220amp Meangreen. Before i put the new alternator on the truck ran fine, the battery light just kept coming on and off. So i put the higher amp alternator in it. Now my transmission is slipping bad. The tow haul light flashes randomy and the truck will get stuck in tow haul mode until i restart the truck.
Any ideas what is going on? Really starting to get frustrated.
Nick20 is offline
post #2 of 8 Old 04-04-2014, 10:24 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
the chances they are related to the alternator are none the 80 hp FICM IDK
did you pull both batteries when doing the work ? just curious it doesn't really point to anything if u did
that flashing is telling you there are codes a decent scanner can read
We Miss you Ronnie
ZMANN is offline
post #3 of 8 Old 04-04-2014, 11:01 AM Thread Starter
I did pull both batteries when I installed the new alternator. It is just weird that when I put the new alternator in the tranny is messing up now
Nick20 is offline
post #4 of 8 Old 04-04-2014, 11:20 AM Thread Starter
Are there any key things I should be looking for when scanning the truck? minus pulling any codes? Like temps? I don't think the transmission fluid has ever been changed since 2004 and the truck has 126,xxx miles on it. Could this also be an issue?
Nick20 is offline
post #5 of 8 Old 04-04-2014, 12:51 PM
Need to scan, then change trans oil, i think every 60k is trans oil change for normal use.
more often if towing or plowing.
Really need to scan for codes to know what's going on.
letitsno is offline
post #6 of 8 Old 04-04-2014, 12:57 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Is your trans temp gauge bouncing around? Mine did that and it ended up being a bad temp sensor causing the issue.
dhanna6powerstroke is offline
post #7 of 8 Old 04-16-2014, 10:28 AM
Quoted: 14 Post(s)
If you remove battery power from the system, transmission needs to go through a relearn procedure.
lenzhotrod is offline
post #8 of 8 Old 04-16-2014, 07:09 PM
4506.0's Avatar
Verify your voltage output isn't too high...
16 F350 CC LB DRW 6.7 FX4
4506.0 is offline
