5r110 slipping on xt tune - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-28-2014, 10:44 AM Thread Starter
koudaddy's Avatar
hi I've been looking for more info on my tranny ..its a 03,5r110 tranny when I put it in xtreme tune from eric sometimes it acts up between 2 and 3 gear, but all the other tune is fine..i email him and he said that its a lazy solenoid not the tune so my ? is which on is it.. I know there is 7 thanks
2003 f250 LB ,6" lifted ,20x12,35x12 toyo, unstudd,eric tune 4" exhaust,cai,sinster coolant filter,procomp traction bar
koudaddy is offline
post #2 of 3 Old 03-28-2014, 06:15 PM Thread Starter
koudaddy's Avatar
anyone change lazyn soleniod out ?
koudaddy is offline
post #3 of 3 Old 04-02-2014, 06:17 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Just saw this and I don't know if it would help but I would change out the direct drive solenoid you can either use and EPC solenoid or get an aftermarket DD solenoid; just Google it. Changing a solenoid is strait forward, drain the pan, remove the electrical connector and then remove the small snap ring. Pull the solenoid out with a twist and then reverse the procedure. It's also a good time to change the filter out, refill with 7 quarts of fluid.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
