Second gear shutter - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-13-2014, 07:32 PM Thread Starter
Second gear shutter
06 f250 6.0 auto trans 4x4 fx.
I am starting to notice a shutter when the trans shifts to second gear under mild to hard acceleration. It usually is gone before the third gear shift.
Would appreciate any advice.
I am considering adding positive traction friction modifier.
I am the second owner of the truck. It is all stock from what I know and has never had a tuner. I do believe he had a fifth wheel on it.
Did know the guy and the truck was sitting for a year before i got it.
Thanks
Richard
RICHE is offline
post #2 of 4 Old 03-14-2014, 08:04 AM Thread Starter
Does anyone know it the TC locks up after the shift to second gear?
I wonder if it is the TC not the second gear clutches.
RICHE is offline
post #3 of 4 Old 04-10-2014, 09:22 AM
Send a message via AIM to zachs04250
Converter locks in at 4-5. Unless you are in tow haul or have a Sat custom program. Mine does it when its cold and pulling a 10k trailer
Ford F-250 PSD
4" Leveling kit
5" exhaust
SCT Livewire Inovative Diesel Tuned
35 all terrains on 18" pro
Inovative Diesel egr delete w/ up pipe
AFE stage II
Gold eagle trans rebuild kit
ATS 5 DISC tourque converter
Smowperformance stage 3 MPG
ported turbo < stock for now >
ARP Studded, P
all new hoses and hpop
low oil pump
zachs04250 is offline
post #4 of 4 Old 04-11-2014, 09:40 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
The converter only locks in 6th gear with a stock tune. If you had a monitor you could see it slip in "D" gear 1, 2, 3, 5 as soon as you add a power. The slips in the lower gears are to protect the transmission from torque multiplier strain.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
