05 tranny not right CODES!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-08-2014, 05:38 AM Thread Starter
z7mathews6.0's Avatar
So this morning my tow/haul popped up and started flashing so I checked codes and I got po766 solenoid D performance or stuck off and the other one is p2703 Transmission friction Element D apply time range or performance. Am I screwed here?!?!
4" MBRP Turbo Back exhaust
Bulletproof diesel 48v powersupply ficm
Sinster EGR Delete and new oil cooler
Sct sf3 tuner with looney tune
2.5 inch level kit and f350 rear blocks
Bilstein shocks all 4 corners
315/70/17 Hankook dynapro atms
2010 ford rims
08 tailgate
z7mathews6.0 is offline
post #2 of 2 Old 03-10-2014, 08:19 PM
From the ford manual
P0766 SSPC-D Direct Clutch SSPC-D circuit, clutch or solenoid failure — OFF.
SSPC-D circuit, clutch or solenoid failed in the OFF position during operation resulting in HIGH pressure in the hydraulic circuit.
Tow/Haul OFF:
No 5th gear available.
Tow/Haul ON:
No 5th or 6th gears available.
P2703 Direct Clutch Direct clutch failed on or off.
The PCM has detected a failure within the direct clutch system. Not all gears available. Tow/Haul OFF:
No 1st, 2nd, 3rd or 4th gears available.
Direct Clutch failed on or off. REFER to PID P0730_Status Chart, found immediately after Output State Control (OSC) Mode in this section, for a specific failure.
REFER to the Solenoid Application charts located at the beginning of Pinpoint Tests — OSC Equipped Vehicles.
If other solenoid DTCs are present, GO to Pinpoint Test A. If only P0730 and/or 2700 series DTCs are present, INSTALL the appropriate clutch solenoid. CLEAR DTCs, road test. If the concern is still present, REPAIR/INSTALL new internal transmission components.
You may have a solenoid failure, you may have a hard part that decided to shell, you could have a fault in a module, or harness without actually being able to test the solenoid I don't really have a good direction to point you in.
Awtblo is offline
