05 F350 takes a while for drive or reverse to engage. - Ford Powerstroke Diesel Forum
post #1 of 18 Old 02-22-2014, 10:00 PM Thread Starter
JaimeG's Avatar
An 05 F350 with 6x,xxx miles recently started taking a while to engage drive and reverse. It only does it sometimes. It also shifts really hard into 2nd and really sloppy into 3rd. Otherwise the truck runs great. I changed trans filters and fluid after it started acting up. The other day the tow haul light started flashing but my Modis couldn't pull the code. What should I look for?
05 F350 CCSB Dually 4x4
Recon Clearance & Mirrors
Newton 2.5" Leveling kit
Toolbox & Transfer Tank
SoundOff Led Mini Bar
Western Wideout
Pioneer DVD HU
JL Audio Amp
Eclipse Subs
5" Exhaust
03 Turbo-Done
JaimeG is offline
post #2 of 18 Old 02-22-2014, 11:35 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
What fluid did you put in?
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 18 Old 02-23-2014, 12:07 AM Thread Starter
JaimeG's Avatar
I used the factory fluid from Ford.
Western Wideout
Pioneer DVD HU
JL Audio Amp
Eclipse Subs
5" Exhaust
03 Turbo-Done
JaimeG is offline
post #4 of 18 Old 02-23-2014, 02:32 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Need to have the code pulled
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 18 Old 02-23-2014, 07:48 AM Thread Starter
JaimeG's Avatar
Yeah, when I hooked up the scanner it beeped and turned on like always, but when it came to reading codes it said there was no communication with the vehicle. The dealer didn't find anything either. Idk where to go from here.
Western Wideout
Pioneer DVD HU
JL Audio Amp
Eclipse Subs
5" Exhaust
03 Turbo-Done
JaimeG is offline
post #6 of 18 Old 02-23-2014, 07:49 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Cig lighter have power?
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 18 Old 02-23-2014, 08:02 AM
look into the line pressure control solenoid.. i had wrote a little bit ago and bumped another thread on this problem.. i had the same symptoms thinking my tranny was going south.... replaced this solenoid and now my tranny is like new(i did this replacement a couple months ago). there is also a tsb on this issue(delay in shifting) from ford. hope this helps
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #8 of 18 Old 02-23-2014, 08:07 AM Thread Starter
JaimeG's Avatar
Last time I checked, it did have power. Also, my scanner will not power on if there's no power tonhe obd port, there's just no communication with the control modules I guess. Let me do some research on that, thanks for the input.
Western Wideout
Pioneer DVD HU
JL Audio Amp
Eclipse Subs
5" Exhaust
03 Turbo-Done
JaimeG is offline
post #9 of 18 Old 02-23-2014, 08:11 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
What scanner did you use?
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 18 Old 02-23-2014, 08:12 AM Thread Starter
JaimeG's Avatar
I'm using a Snap-On Modis.
Western Wideout
Pioneer DVD HU
JL Audio Amp
Eclipse Subs
5" Exhaust
03 Turbo-Done
JaimeG is offline
