2004 f250 trans problems - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-15-2014, 06:38 PM Thread Starter
after plowing with the truck came home shut it off for about an hour restart truck when put into reverse took about 5 seconds slammed in and stalled. I have 3 codes po741 torque conv clutch circuit stuck off po766 shift sol d stuck off po 757 shift sol b stuck on. last few hours of plowing tow haul light in dash was on
ErichR1969 is offline
post #2 of 9 Old 02-15-2014, 06:44 PM
ZMANN's Avatar
Quoted: 1587 Post(s)
doesn't sound good whats the fluid look like ?
We Miss you Ronnie
ZMANN is offline
post #3 of 9 Old 02-15-2014, 08:30 PM Thread Starter
checked fluid no metal or dirt just changed 1000 miles ago
post #4 of 9 Old 02-15-2014, 08:44 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Mine didn't look burned or have metal either when it started acting up. I had to replace the trans.
dhanna6powerstroke is offline
post #5 of 9 Old 02-16-2014, 06:56 AM Thread Starter
I will be checking the wiring conections and hope to find something hoping not to have to rebuild or replace
post #6 of 9 Old 02-16-2014, 09:19 AM
sixltr's Avatar
Customer Statisfaction Program 04B24 relates to delayed reverse engagement, very common in plow trucks, look for leaks or cracks near the back of trans on the top.
2006 EC Dually 4x4 4.10 Auto
Batmowheel
Sct livewire ts
4" Flo pro exhaust
Cat elc
Bd boot kit
Rancho 7000 shocks
Firestone air bags
Rotella T6, Archoil 9100
PHP Ficm tuner
Studs with OEM gaskets
S&B cold air intake
Sinister coolant filter
Spearco Intercooler
sixltr is offline
post #7 of 9 Old 02-16-2014, 09:36 AM Thread Starter
I only plowed with this truck this year trans has 129000 on it and about 100 plow hours.dont see any leaks or cracks has delay both drive and reverse. thankyou
post #8 of 9 Old 02-16-2014, 09:38 AM
Mod Newbie
Quoted: 20 Post(s)
That TSB 04B24 was over in 2005. Just pointing that out in case you try to get it looked at under that TSB
post #9 of 9 Old 02-23-2014, 07:50 AM
JaimeG's Avatar
Any updates?
05 F350 CCSB Dually 4x4
Recon Clearance & Mirrors
Newton 2.5" Leveling kit
Toolbox & Transfer Tank
SoundOff Led Mini Bar
Western Wideout
Pioneer DVD HU
JL Audio Amp
Eclipse Subs
5" Exhaust
03 Turbo-Done
JaimeG is offline
