Transmission Problems - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-06-2014, 05:22 PM Thread Starter
I put my truck in reverse today and it would not take until around 2k rpms same with drive. The code i have are P1744, P0720, P0756, P0766, P2701, P2703.
Yesterday i was coming home from work and i lost 5th gear then it acted like the transmission was just slipping then took fourth and did that all the way down to first. I shut the truck off and then it ran and drove just fine.
A Few days before that i got the P1744 code for the torque converter solenoid if i remember right. It would go to 5th lockup and then a little while after that it would unlock. It would still drop the rpms half the normal amount that it does when the torque converter would lock though.
Cntryby95 is offline
