transmission difference - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-03-2014, 03:25 PM Thread Starter
Have a 2004 ford f250 and im trying figure out whether i have a 4r100 transmission or a 5r100 transmission. They say to not mix the trand fluid between the two so im trying to find out a way to tell them apart so I know what to get.
bigk33 is offline
post #2 of 3 Old 02-03-2014, 04:14 PM
powerstrokecrzy's Avatar
Quoted: 250 Post(s)
5r110. 4r100 was matted to the 7.3.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #3 of 3 Old 02-06-2014, 05:05 AM
ATV PRO 11's Avatar
5R110 is correct
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
