YIKES! That's Tight! - Ford Powerstroke Diesel Forum
post #1 of 20 Old 12-20-2013, 09:12 PM Thread Starter
DVCF450's Avatar
Well, I just drained the pan and replaced with a Derale cooling pan. Planed on changing filters, and after completing the internal turned my attention to the external filter housing. Could not loosen it with 3/8, 1/2, 3/4 ratchets or breaker bars. Tried the 'ol strap wrench. NADA. Managed to turn the whole assembly, but could not access the filter. What do they use on these things..." impacts? Sprayed the top of the housing with some penetrating oil, but no joy. Any ideas...that don't require a blasting license...to get that sucker loose with out damage?
2005 F-450 4WD DRW, 2x Deka 665MFs, 55w 6k headlights, BPD EGR cooler,BPD 100mm water pump,BPD all aluminum radiator,DC Power 190 amp Alternator,Utility box,high idle mod.,Sinister coolant filter, home built radio center console, Fumoto oil valve, Edge insight with SCT SF-3 in overhead mount,blue spring mod., BPD FICM, Derale deep cooling pan, BPD oil cooler, Jasper engine block & heads, ARP headstuds
DVCF450 is offline
post #2 of 20 Old 12-21-2013, 04:39 AM
I haven't changed mine for the same reason.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #3 of 20 Old 12-21-2013, 06:59 AM
ATV PRO 11's Avatar
Read somewhere on here the impact gun does the trick to take it off. Supposedly does less damage than the torque of long wrenches ect.
Same with putting it back on. But they reccommended it be someone familier with their gun to stop at the 1st/2nd ratchet of the gun.
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
post #4 of 20 Old 12-21-2013, 07:26 AM Thread Starter
DVCF450's Avatar
Thanks for the replies!
I stopped when the bracket and assembly started to bend with the torque. An impact seems to be the way to go...wasn't on my Christmas list, but I would feel better changing all the filters, not just the internal. What brand/ size impact wrench do y'all recommend?
DVCF450 is offline
post #5 of 20 Old 12-21-2013, 07:33 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1709 Post(s)
Feedback Score: 4 reviews
^^^Yep, impact with a 22mm to take it off.....I wouldn't use it to put it back on though ...it's just cast aluminum....just hand tight and then a good snug.
Can't go wrong with most impact guns for around the home occasional use. I have a Chicago Pnuematic 1" gun, a BluePoint 3/4", 1/2" and 3/8"", but my favorite is my Snap-On 18V Electric 1/2" drive. Unless you're working in a shop all the time, a good quality 3/8" impact will do 99% of what you're probably wanting to do with it. If you think you'll want to use it down the road for some bigger stuff (leaf springs, lots of tires, etc.) then go for the 1/2" drive.
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #6 of 20 Old 12-21-2013, 07:42 AM Thread Starter
DVCF450's Avatar
Thanks, Nighthawk
Snap-On and Blue Point may be a little over kill for my budget right now, though I usually don't skimp on tool purchases. I'll try to find a decent 1/2" impact, probably air powered, and between that and my 3/8" ratchet should tackle most things on this beast.
Many thanks to this forum, which has gotten me over the fear of doing anything, besides washing it!
DVCF450 is offline
post #7 of 20 Old 12-21-2013, 07:44 AM
Yeah, the BluePoints were a garage sale find ($50 for all 3).....a Chicago Pneumatic would be a great starter gun for you! Or an Ingersoll Rand....both are pretty well priced and high quality.
post #8 of 20 Old 12-22-2013, 08:16 PM
Do not use an impact gun for thi..... what in the world lol... take a butane torch to it and heat it up. Will loosen right up
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #9 of 20 Old 12-22-2013, 08:33 PM
^^^IIRC Greg that's even what it says to do as Ford spec. for how to remove it, I could be wrong though...looking for the tech file now.
post #10 of 20 Old 12-22-2013, 08:42 PM Thread Starter
DVCF450's Avatar
I had not considered a torch...it would save me another expenditure this time of year, but hot flames near a vessel full of paper and tranny fluid seems a bit risky. I will look into the tech files, as well.
Thanks for all your replies!
DVCF450 is offline
