Torqshift acting up engaging into drive - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-19-2013, 06:27 PM Thread Starter
Hey folks, got a problem with my torqshift and couldn't find any other post with my same symptoms so I figured I'd ask the pros. I have a 2006 f350 standard cab,4x4, 6.0 187k and recently it started a delayed engagement into drive. It doesn't do it all the time but probably 7 out of 10 times but most always from park to drive every time it's started up( warm or hot doesnt matter). When it's shifted into drive I get a slight engagement then "falls" out of gear then about a second later re-engages. Once it's fully engaged it shifts real nice and doesn't seem to have any issues.. No shudder in OD or slipping. If anyone can try to point me in the right direction it would be greatly appreciated!
Sbarlow87 is offline
post #2 of 4 Old 12-21-2013, 12:23 PM Thread Starter
Alright quick update folks, did a internal filter, external, and fluid change.( not flush just dropped pan). the internal screen had some fine particle embedded into it and the external TP roll was black with a film of grey sludge on it. After driving about 20 miles it seems to be shifting a little smoother but still has the momentary engage-disengage-engage into drive . Not as much as before but still there... Any pointers? I'm really dreading bring it to the dealer
ford:350 reg cab 4x4 187k
4'' rancho lift w/ re arched HD rear springs
315 BFG's, Mickey thompson beadlocks
ford billet grille
swapped leather interior(heated seats)
swapped chrome/ power mirrors
banks six sun w/ speedloader
boost& egt gauges
4'' banks exhaust
banks intake
banks intercooler
egr delete(coming soon)
post #3 of 4 Old 12-22-2013, 06:25 AM
line pressure control solenoid can be clogging up... There is a tsb on this issue. Replce the solenoid
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #4 of 4 Old 12-27-2013, 06:02 AM Thread Starter
Is this something I could just drop the pan and replace the solenoid?
ford billet grille
boost& egt gauges
4'' banks exhaust
banks intake
banks intercooler
