Slipping in Forward and Reverse trouble - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-05-2013, 07:00 AM Thread Starter
ATV PRO 11's Avatar
Wonder if anyone has experienced this.
Drove the wife to work this morning.
The turn off into town there was a lady stuck so I pulled over in the drifts and helped her out.
After putting in back in gear I had to get on it to get out of the drifts.
Snow was blowing over the windshield, and I imagine throughout the engine bay.
After that it felt like it stayed in 2/3rd gear.
I'd hit the pedal and it would redline and sort of accelerate jumping in and out of gears. So i slowed down to a stop. Accelerated slow and it was ok but when I got more on the pedal it would feel like it was slipping.
Once I got in the driveway, she idled for about 15 mins while I shoveled out my spot. Once putting in gear again I had to rev it up for it to move.
Also reverse, had to rev it up to move it.
Any feedback on this guys/gals?
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
post #2 of 6 Old 12-06-2013, 06:39 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
I thought I had a copy of this, but if it is a solenoid issue use this to help. Go to post 29 need transmission guru's help - Page 3 - TDG
As well, this is a very good thread for information: TorqShift Transmission - Information and Troubleshooting - Ford Truck Enthusiasts Forums
an excerpt:
Originally posted by Bismic on FTE in 2009
Not sure if this applies, but fyi -
The issue with the 04's involved replacement of the reverse planet assembly due to low/reverse gear set pinion shaft(s) that may walk out. Vehicles affected were built from 03/08/04 through 06/24/04.
Recall on 2004 TorqShifts:
Certain trucks built from 3-8-04 through 6-24-04 may experience a failure of the low/reverse planetary assembly. Specifically one or more of the planet gear pinion shafts may walk out of the carrier. If this occurs metallic contamination of the fluid will occur and will cause harsh or slipping shifts and/or harsh or delayed engagements in forward or reverse. Trucks affected by this recall will have the low reverse planetary replaced if no damage has occurred, or will have the transmission overhauled and repaired as needed, along with replacement of the transmission cooler, if damage has occurred. This recall has been extended until 3-31-06
Customer Satisfaction Program 04B24.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
The Following User Says Thank You to twoicebergs For This Useful Post:
ATV PRO 11 (12-08-2013)
post #3 of 6 Old 12-08-2013, 06:39 AM Thread Starter
ATV PRO 11's Avatar
Good Morning Frank.
I found Bismacs thread the other day when searching.
I'm going to replace the solenoid anyway. I went out that afternoon after it happend and it continued throwing the blinking Tow/Haul mode light at me. That's when I remembered in the summer I had the same issue.........Right after washing the truck in Birdshill. I did pull over, after a long warm up and very light on the right foot to get everything warmed good and restart the truck. It drove fine for the remainder of the hwy trip I needed to take with it. No problems.
I would assume, blasting through the snow after pulling the lady out with the powertrain hot and nailing the big drifts that the snow either shocked the module or water actually penitrated the device. Either way, it may or may not solve the problem but will answer the question wether it's the solenoid or actual transmission problems showing themselves. I also checked the build date of my girl, 02/04.
Thanks for the reply, again, appreciate it.
If there is every anything I can do to help you out, just let me know!!! I'm not cheap but i'm easy
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
post #4 of 6 Old 12-16-2013, 03:42 PM Thread Starter
ATV PRO 11's Avatar
Such a simple fix.
5R110 Torqshift problem resolved
I've been reading through posts for days with my issues. Posted a thread for help as well. This worked for me today. Post 1 did it. Shifting waaaaay better today with hwy and city driving. The more I drove the better it shifted.
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
post #5 of 6 Old 12-16-2013, 08:14 PM
Quoted: 46 Post(s)
So, all you did was clean the connector. Such a simple fix!
Frank
Working for Toys
post #6 of 6 Old 12-17-2013, 07:48 AM Thread Starter
ATV PRO 11's Avatar
Yes, The connector on the top Drivers side. Had some ice around the connector and the little clip that keeps it locked in was broken. Didn't actually notice ice in it as I was laying under the truck but used zip ties until I can get a new pigtail wired in. It Still have code P1000 code but i'm sure that will go away with some more driving. Certainly helped it alot since. Just hope it's not a short term fix.
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
