5R110 Relearn issue - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-25-2013, 06:06 PM Thread Starter
dalton1's Avatar
5R110 Relearn issue
I recently had the batteries unhooked on my truck for over a week and now I'm having transmissions issues. every time i drive the truck it shifts terrible, revs slams, then the tow/haul light will start blinking and the trans starts shifting great. then when i turn the truck off and restart it, it starts happening all over again.
pulled codes and got P0730 and P2703.
Also delays going from park to drive and park to reverse but i believe that is caused by a bad EPC solenoid. this was happening before but has gotten worse.
any ideas?
03 F-250 Lariat Crew Cab SB 6.0L Auto 4x4
5" exhaust, AFE intake, Blue spring mod, EGR Delete, 58v FICM, Warren 175/75 injectors, Powermax Turbo,
ARP Head Studs, Coolant filter, Innovative tunes
Pine Tree Powerstroke Association Director
pm me for chapter info
dalton1 is offline
post #2 of 5 Old 11-26-2013, 03:25 PM Thread Starter
dalton1's Avatar
Anyone? I can't figure this out, also it's not going into o/d with the light blinking.
dalton1 is offline
post #3 of 5 Old 11-26-2013, 04:09 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
I certainly am no specialist when it comes to transmissions, but I looked up the codes..
Posted below from alldata..and these links are only good for a few hours.
If they change before you get a chance to check them out, message me.
Please
You could save the life of a sick child
NYC F-350 is offline
post #4 of 5 Old 11-26-2013, 04:21 PM
elchaseo's Avatar
Quoted: 8 Post(s)
Tranny Re-learn question
See post 2
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #5 of 5 Old 11-27-2013, 06:34 PM
turbotibbo's Avatar
stick a modified dd solenoid in there or disconnect the batts again and do a proper relearn
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
