will not shift out of o/d? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-17-2013, 07:16 AM Thread Starter
01powestroke's Avatar
Going to look at this truck some time this week, and in the add it says that the trans sifts good all the way up to o/d then when you slow down it will not shift out of o/d unless the truck is shut down and restarted again. It is an 03 f350 6.0 with 250k miles on it, Im just wondering what could cause this, is it most likely that it needs a rebuild or is it probably a solenoid or maybe even the wrong fluid?
2001 f250 lariat 7.3 3.73 rear end 4" exaust with muffler-5"tip eagle alloy rims with 305/70 firesteone at, superchips programmer
2002 dodge durango slt+ 4.7v8 flowmaster super 10, intake, ho cams ,superchips programmer, trying to trade it for a diesel
01powestroke is offline
post #2 of 3 Old 11-17-2013, 07:18 AM
DoubleDpsd's Avatar
Most likely needs a new tranny. Sounds like it is in limp mode.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
The Following User Says Thank You to DoubleDpsd For This Useful Post:
01powestroke (11-17-2013)
post #3 of 3 Old 11-17-2013, 07:20 AM Thread Starter
would limp mode let it shift 1-5 then just stay in 5th?, I have no idea how it works on these trucks but on my durango when it goes into limp mode it will start in 3rd and stay there
