is this the infamous bedplate leake? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-19-2013, 06:22 PM Thread Starter
JustinOOO9's Avatar
Quoted: 421 Post(s)
Garage
the picture is may with my head towards front of vehicle, so the oil drip is onhair to the pass side of the center on forward most part of trans, it doesn't appear to be coming out of the small plastic cap thing just the seem?
i wiped it down yesterday and its back
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes,
currently-1999 F250 SBRB 4X4 First 7.3, 6.0 trans cooler made my muffler fall off
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #2 of 7 Old 10-19-2013, 06:33 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
Pop the inspection cover and look for a trail.
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 7 Old 10-20-2013, 07:26 AM Thread Starter
JustinOOO9's Avatar
Quoted: 421 Post(s)
Garage
does the inspection cover pop off with like a small screw driver?
what do I look for once its open?
I did some research on the bedplate so im gonna try and check around the motor more but im just not sure I want my engine ripped out and torn down that much for 2 small strips of permatex...
anyone have any other tips other then just looking for oil leaks? im posative its not trans fluid
1. bed plate
2. rear main seal
3. maybe some small o rings
4. glow plug harness
5. dip stick o-ring
6. turbo
any other ideas?
Justin,
post #4 of 7 Old 10-20-2013, 07:42 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Check the turbo oil drain tube and if you have to pull the hpop cover and make sure the rear cover isn't cracked or leaking before messing with a rear main or bed plate seal.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 7 Old 10-20-2013, 08:49 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Quite often if the pan is mistorqued or loose it leaks oil and mimics other leaks. Just something to think about.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 7 Old 10-21-2013, 08:04 AM Thread Starter
JustinOOO9's Avatar
Quoted: 421 Post(s)
Garage
progress update:
--drivers side glow plug wires are clean
--dip stick o ring is good
--pass side glow plugs look clean but really hard to tell
-- pass side of block towards front of trans has some oil residue but i can't quite get good look at it, its not close to trans though and my engine oil pan is mostly dry
next questions:
so what should i look for behind the little plastic or rubber inspection cover on trans? and do i just use a flat head screw driver?
for turbo oil feed or drain tubes just a mechanics mirror or can i look if i lay on engine bay?
thx im not a diesel tech so this is kinda new really digging in the engine bay haha
Justin,
post #7 of 7 Old 11-05-2013, 05:42 PM
STROKINFX4's Avatar
Let me know what you find, I have the same drip. I can wipe it and it's good for a few days before it drips again.
STROKINFX4 is offline
