Shift Issue - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-21-2013, 12:52 PM Thread Starter
Shift Issue
From park to reverse there is about a 10 sec delay before it clicks in finally. also is doing it from park to drive. any ideas?
2003 silver fx4 crew cab drw. 4" lift, dual fox shocks up front, single fox shocks resevoirs in back. 35" tires, rear spacers, EGR delete, 3.5" down pipe, 4" straight pipe, smoked cab lights and rear lights. SCT Livewire. 80k miles.
03drw is offline
post #2 of 4 Old 09-21-2013, 01:54 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Low fluid level? Old fluid lost its viscosity and needs to be changed? Restricted/dirty filter? Bad line pressure solenoid? Bad clutches and/or bands? High miles or lots of towing or WOT pulls and time for a rebuild? Some tunes affect shift points... accidental setting?
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
post #3 of 4 Old 09-23-2013, 11:36 AM Thread Starter
I will start with changing fluid and filter although fluid looks new still on the stick. Truck has 83k miles, no towing.
03drw is offline
post #4 of 4 Old 11-06-2013, 12:20 PM
any update to this?
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
