Shifting problem - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-17-2013, 04:13 AM Thread Starter
ymraspc's Avatar
Send a message via Yahoo to ymraspc
Shifting problem
So in the mornings the truck doesn't want to seem to shift until its almost at 3000 rpm and I'm barely on the accelerator.... just checked my fluid and its barely registering on the stick. I will be adding some today, but would it cause it to do that? Also checked and its not leaking anywhere, so I'm not sure how it even got low in the first place. Please help. Thanks
Wifes ride 2006 Crew Cab F350
With Rancho Lift Kit and 35X12.50R18 Toyo Open Country MTs
'01 2500 White,EC, LWB, 272k...HX40 Turbo, DD-2 injectors, BHAF, Holley Black Label Fuel Pump, Vulcan Big Line Kit, Suncoast Valvebody, 4" exhaust, egt gauge, boost gauge, trans temp gauge on pillar mount, fuel press gauge, TST PowerMax3, Silencer Ring MIA
Sold to move to England in 2010
ymraspc is offline
post #2 of 10 Old 09-18-2013, 04:41 AM Thread Starter
ymraspc's Avatar
Update..... I added 2 quarts of mercon lv and it seems like nothing really changed aside from it having the correct level now. This morning it was still taking too long to shift. I plan on doing the fluid in the pan and filters change next, but I would like to know if that could even be the issue. Or is my trans about to go out?
ymraspc is offline
post #3 of 10 Old 09-24-2013, 09:19 AM Thread Starter
ymraspc's Avatar
So now it seems to be doing it even more, but especially if you get on the throttle, and if you get over like 50mph, it doesnt want to shift....... Any and all help is appreciated fellas, I dont know anything about these 5R110s. Could it be just a simple fluid and filter change? Torque Converter?
ymraspc is offline
post #4 of 10 Old 09-24-2013, 10:31 AM
shenanigans
junior125's Avatar
Quoted: 1488 Post(s)
Garage
know anyone that has access to either AE or IDS?
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, ODAWG S3R, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #5 of 10 Old 10-04-2013, 05:10 PM
Quoted: 2 Post(s)
I too have this issue until the tranny temp gets up to operating temperature, then it shift fine even under WOT. Is this always the case when cold? I'm new to this truck so still getting to know its intricacies. Also, does ECM strategies also apply to TCM as well are they 1:1 or independent of one another? Did previous strategies have been shifting conditions when cold?
jwoodzx7r is offline
post #6 of 10 Old 10-13-2013, 05:44 PM
Cold tranny slow shift
Hey I'm new to this site and was wondering if there was any solution to this cold tranny no shift I'm having the same problem
SDlover is offline
post #7 of 10 Old 10-13-2013, 05:54 PM
sargar's Avatar
Have any of the guys having the shifting problem had the trucks checked for codes? What y'all are experiencing is not normal, unless I'm not understanding what you are saying. I'm reading that your trans is holding low gear too long until it warms up. Yes, no, maybe?
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #8 of 10 Old 10-13-2013, 06:01 PM
No I never had it checked for codes yet but ya that's what mine is doing holding low gear until it warms up
SDlover is offline
post #9 of 10 Old 10-13-2013, 06:03 PM
After it warms up it shifts great just started doing it when it started getting cold worked fine all summer
SDlover is offline
post #10 of 10 Old 10-13-2013, 06:09 PM
sargar's Avatar
A lot of people will disagree with me, and I don't want to get into a debate about it, but what you just described may be fixed with a transmission flush. Look up BGProducts online and find a shop near you. You are looking for a PF-5 service. This is not a drop the pan/partial fluid exchange but rather a cleaner followed by a 100% fluid exchange. Yes, I've done it on my own SD as well as others.
Edit: http://www.bgprod.com/products/transmission.html
sargar is offline
