sticky please! proper atf usage - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-08-2013, 05:22 AM Thread Starter
New to the forum still but noticing a couple people saying they used fluid other than mercon sp. To my knowledge motor craft is the only maker of this fluid. I haven't found any other fluids that are compatible. Using the wrong fluids can cause your transmission all kinds of weird issues as they can eat up the shift solenoids. They are especially important on our 5r110s as they are completely electronic controlled.
BTW I have seen it first hand and been told this same info from my local transmission shop
Late '04 F350 6.0, studded, 4" exhaust, intake and programmed
ford350f7 is offline
post #2 of 6 Old 09-08-2013, 12:09 PM
Quoted: 58 Post(s)
Redline D6 ATF is a suitable (if not better) alternative for these trucks.
Specs: http://www.redlineoil.com/product.aspx?pid=115&pcid=9
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 6 Old 09-13-2013, 11:47 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Amsoil makes a great Mercron SP/LV approved ATF oil.
AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 6 Old 10-04-2013, 01:37 PM
HP MACHINE's Avatar
Quoted: 162 Post(s)
My question is can they be mixed with the residuals left behind from the old fluid ?
Would multiple pan drops ( 2 or 3 ) in a row be ok ?
HP MACHINE is offline
post #5 of 6 Old 10-05-2013, 12:35 PM
Quoted: 8 Post(s)
Yes you can mix the two (I'm assuming your talking about synthetic fluid). Mixing synthetic fluid with non synthetic is just like running a synthetic blend. (Kinda like Rotella T5 engine oil) or you might be referring to SP and LV... But even those can be mixed without problem. I wouldn't drop the pan several times within a short period of time though, just keep up with regular maintainence on the trans and you'll be fine!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 6 Old 10-07-2013, 06:10 AM
HP MACHINE's Avatar
Quoted: 162 Post(s)
Thanks for the reply , I shifted from sp to lv gradually last round with a larger pan .
I believe I changed 8 liters and added 4 more ( over sized pan ) = 12 liters .
My trans works fine , but I think I'm going to switch to Amzoil this time . When I say
pan drops it means I have a drain plug which makes it easy , measured coming out
and back in .
I also run a Dieselsite filter set up , which I highly recommend .
