Trannie slip with street tune. What now? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-01-2013, 01:19 PM Thread Starter
mikystyle's Avatar
I have had my SCT with a custom street tune for bout 2 yrs now and have been noticing under heavy acceleration truck would feel like it shifted but rpms don't change which I assume is the transmission slipping. I restored the truck back to stock with the programmer and problem is gone except now she's a dog again.
Would like to retune especially since ill be installing an EGR delete soon. What am I in for with the transmission? Rebuild?
2005 HD Edition F250
8" Fabtech 4-link Lift
37" Pro Comp Xtreme A/Ts on 20" XD Revolvers
K&N Intake
4" Straight Pipe
SCT Livewire
Bulletproofed
mikystyle is offline
post #2 of 5 Old 09-02-2013, 06:55 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Most of the tunes out there allow for some TC slip and some allow for quite a bit, depending on pedal position and load. Since you don't have other HP mods, it is unlikely you have slipping trans clutches or a slipping TC, but it is possible depending on the abuse it may have taken over the years. The best way to proceed is to get the specifics of your tune and when the TC is suppose to be locked or how to lock it. I was surprised to find one of my race tunes was not locking in 5th no matter how hard I tried; that really screws up a dyno run with 1000 rpm of slip!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 5 Old 09-02-2013, 07:53 PM Thread Starter
mikystyle's Avatar
Truck has never towed and I don't beat on it to badly so I wouldn't think abuse is an issue.
Would locking it via the tune cause any other problems? Why would slippage be allowed in a tune?
K&N Intake
4" Straight Pipe
SCT Livewire
Bulletproofed
post #4 of 5 Old 09-04-2013, 06:24 PM
Quoted: 47 Post(s)
Slippage is normal as it allows the RPM to increase to not bog down and for smoother application of power. It is easier on the drive-train. With higher power, you need to lock it earlier to get the power to the wheels. As well, locking it for towing does give you an engine brake, but can also cause lugging issues when under the turbo and power-band.
Frank
Working for Toys
post #5 of 5 Old 09-04-2013, 06:41 PM Thread Starter
mikystyle's Avatar
All good info, thanks!
K&N Intake
4" Straight Pipe
SCT Livewire
Bulletproofed
