Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Trannie problems
  #11 (permalink)
Old 05-20-2008, 03:37 PM
darsey715 darsey715 is offline
Send a message via AIM to darsey715
Originally Posted by Hillbilly_6.0 View Post
Well I took my truck to Advance yesterday. No codes whatsoever. It was doing fine on the way there so I thought that it must of been the full moon Saturday night lol. On the way home it done it again, pegged guage, flashing light, and hard clunky shifts. It stayed that way the whole way home but it started shifting normal. So I'm just not gonna drive it till I can take it to the tranny shop toward the end of the week and have them look it over. This is stressing me out.
I would not trust a torqshift transmission at a "tranny shop". I doubt advanced even has the diagnosis equipment to read tranny codes off of these computers. A reputable tranny shop may have the right scanners, because there is definitely a code. If you can afford it, just take it to a dealer you trust. good luck to you man.
  #12 (permalink)
Old 05-20-2008, 04:09 PM
Hillbilly_6.0 Hillbilly_6.0 is offline
Yeah I'm not gonna trust them either after I talked to them today. The guy said he hadn't worked on those trannys before. I'm gonna call the dealer I bought the truck from and have them look at it. I know it was odd that Advance didn't pick up any codes.
  #13 (permalink)
Old 05-20-2008, 04:11 PM
Originally Posted by MAH6.0 View Post
I have a 2005 ford 6.0 and my truck is doing the same thing. The tow/haul light keeps flashing off and on. The check gauges light keeps coming on. I have a edge programmer and exhaust. The edge program read a PO113 code and I looked it up. Its reading a high temp input sensor. How much does a senor cost?
If it is a sensor causing this I'd put it in myself. I'd say it's probably a Ford only piece. If thats what its called I see tomorrow how much one is.
  #14 (permalink)
Old 05-20-2008, 04:20 PM
I doubt a sensor would be causing hard clunky shifts
  #15 (permalink)
Old 05-22-2008, 11:42 PM
ipz2222 ipz2222 is offline
It's a bad trans temp sensor in the trans. Very common problem. Any independent trans shop can service the trans and replace the sensor at the same time. Depending on your location, around $150 to $250.
  #16 (permalink)
Old 05-23-2008, 06:20 AM
MAH6.0 MAH6.0 is offline
tranny
Thanks for you the response.
  #17 (permalink)
Old 05-23-2008, 02:19 PM
Yep, thats what it turned out to be. I took it to Ford today. The yran the tests on the truck and said the sensor was actually reading "below zero" in their words. They said that was the first they had seen.
  #18 (permalink)
Old 05-25-2008, 07:33 PM
Oh. I took my truck to west coast diesel performance. They found that it was a bad sensor in the tranny. It cost me 800 bucks! They also did a transmission service on it too.
  #19 (permalink)
Old 05-25-2008, 07:38 PM
they should have a smiley holding up a sign that says "raped!".
  #20 (permalink)
Old 05-26-2008, 06:17 PM
$800!!!! That is so outragoues , I don't even believe it.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
