whats the reality of the 3-5 flare? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-20-2013, 05:28 AM Thread Starter
So ive read alot about the 3-5 flare, but theres no consensus about what it really is caused by, or how to fix it. I had it with SCT canned tunes bad, but got MPD from truck source and it seems to be alot better. Is it the direct drive solenoid getting weak? Would getting a new stock solenoid help or do I need to get the ones that are basically a gogo solenoid?
Thanks
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #2 of 3 Old 08-20-2013, 01:41 PM
you can do either solenoid... If your transmission had a issue than the solenoid will just bandaid it and give you more time- if your trans is in good shape than it can work nicely and prolong some issues.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 3 Old 08-22-2013, 02:59 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'm no transmission expert but on my tow tune (right after programming it) has a nasty 3-5 flare only while the trans is in its relearn process. I can always make it go away by:
1: 0-30 mph 1/4 (3-5 flare present)
2: 0-30 mph 1/4 (3-5 flare gone)
3: 0-45 mph 1/2 (3-5 flare present)
4: 0-45 mph 1/2 (3-5 flare gone)
5: 0-60 mph 3/4 (3-5 flare present)
6: 0-60 mph 3/4 (3-5 flare gone)
7: 0-75 mph WOT (3-5 flare present)
8: 0-75 mph WOT (3-5 flare gone)
After doing each run I allow the truck to slow down a few mph before stopping the truck and starting the next run.(don't hit the brakes immediately after the truck reaches the desired mph for that run) After doing this process while the trans is in a relearn it completely takes my 3-5 shift flare away. I've tried this with my extreme tunes and it cures the flare 90% of the time. Just makes sure you find a road that allows you to start and stop several times and that you just reprogrammed the truck. I would try this before changing solenoids.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
