Transmission bog - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-14-2013, 04:50 AM Thread Starter
paintballbryce's Avatar
Transmission bog
On the way to work this morning, had to give it to the floor to get into the proper lane, as I was stuck in traffic, and when I got over and the turbo lit, my truck starting reving out and sounded like I was running 4lo, and stuck in a lot of mud. Never had this happen before, any suggestions? I was going to try and fluid flush. Can't afford a new one until spring, so this will hopefully last me?
Thanks!
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 2 Old 09-24-2013, 08:26 AM
ymraspc's Avatar
Send a message via Yahoo to ymraspc
My issue is similar to yours, and Im in the same situation. I cant afford a new one right now either. Did you ever try the fluid and filter flush? If so did it work? Any help on these would be greatly appreciated.
Wifes ride 2006 Crew Cab F350
With Rancho Lift Kit and 35X12.50R18 Toyo Open Country MTs
'01 2500 White,EC, LWB, 272k...HX40 Turbo, DD-2 injectors, BHAF, Holley Black Label Fuel Pump, Vulcan Big Line Kit, Suncoast Valvebody, 4" exhaust, egt gauge, boost gauge, trans temp gauge on pillar mount, fuel press gauge, TST PowerMax3, Silencer Ring MIA
Sold to move to England in 2010
ymraspc is offline
