Trans cooler - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-12-2013, 12:17 PM Thread Starter
LiftItUp's Avatar
Trans cooler
I burned my transmission up. Temps reached 281*. New Trans is goin in this week. My question is do i need to replace the cooler also? Not sure if it got fried or not
07 ccsb lariat 4x4
Lifted 35s
Bone stock for now
Traded
late 99 ccsb lariat 4x4
6" procomp
37" m16s
4.88 gears
tw
autometers
diy intake 4" MBRP cat delete
foil delete
LiftItUp is offline
post #2 of 4 Old 08-12-2013, 03:37 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Wow that's hot! If it doesn't leak I would at least flush the lines out and make sure something isn't plugging the cooler or lines!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 4 Old 08-13-2013, 09:55 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Very hard to clean a stacked plate cooler..so have it professionally cleaned and then use a filter on the output or use a new one..
CT Performance, Inc. is offline
post #4 of 4 Old 08-13-2013, 10:51 AM
it's recommended that you put a new one in when you have a failure that puts debris into the cooler. like CT said it's hard to clean them, but if budget says reuse, get it as good as you can plus a little more. and a filter in the return wouldn't be a bad thing for a while too.
tommymacher is offline
