Tranny down! Help! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-03-2013, 08:38 PM Thread Starter
southern raised's Avatar
Tranny down! Help!
So i was in my way home and suddenly the tranny shifted real hard, then it quickly got worse and worse to every shift was horrible and now it wont shift i had to idle home about 15 miles, my SCT tuner is pulling codes p0706,p0707,p0730,p0701,p0702,p0703 i believe all tranny codes so any info could help? Do i need a new tranny or is it not too bad? Thanks
Sent from AutoGuide.com App
southern raised is offline
post #2 of 7 Old 08-03-2013, 08:40 PM Thread Starter
My truck is an 04 with 03 6.0 egr delete, studs,gaskets oil cooler SCT custom tunes intake and custom exaust
post #3 of 7 Old 08-03-2013, 09:56 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Check your tranny oil, does it look burnt? Maybe low fluid level or leak. Check fuses, all the codes are related to transmission most of them are electrical. I'm really just throwing ideas out there, I'm no subject matter expert on the torque shifter.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #4 of 7 Old 08-04-2013, 08:20 AM Thread Starter
Yea it was pretty bad tho im hoping its not fried
post #5 of 7 Old 08-04-2013, 10:00 AM
You can drain the transmission and remove the pan to see if you see something. If not, I would drain and fill transfluid and change filter. Then see what she does.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #6 of 7 Old 08-04-2013, 11:17 AM Thread Starter
Thank you ill give it a try and see what happens
post #7 of 7 Old 08-16-2013, 12:50 PM Thread Starter
I dont think its tranny related, i havnt had time to lookin into it and i took it around the block once and when drive with little gas it has a loud clicking noise coming from bhind the dash and it wont shift good and when i come to a stop it will rev up, when i give it a little gas when driving around its not as bad, does any1 have an idea?
