Dealer fluid flush question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-25-2013, 01:07 PM Thread Starter
Quoted: 2 Post(s)
I called my local dealer and asked if they have the machine to do a proper trans flush with the heated fluid. They thought I was nuts. They said (after calling me back, said he had to talk to his tech) that their machine "overrides the thermostat" so it isn't necessary to heat it.
Will the flush here be a good one? $200.
I've had the truck since 94,000 and have no idea if it's ever been flushed (or even changed).
Idahoser is offline
post #2 of 13 Old 07-31-2013, 06:02 PM
I am curious, I want to do the same, but am concerned to do it because I have heard of stories of people having trouble after a complete flush. I have no transmission problems and only 70,000 on an 03.
Patrick
goltzp is offline
post #3 of 13 Old 08-26-2013, 05:02 PM
MoserJR82's Avatar
I'd like to know as well. Starting to shutter when backing up and will sometimes hang up on a gear in WOT. Truck has 153K and I doubt it's ever been flushed..
2005 F-350 KR, CC, SB 6.0L
Sinister EGR Delete
Final Charge Coolant
Rotella T6 5w40
Sinister Coolant Filter
MBRP 4" turbo back straight pipe
Blue Spring Upgrade
Droid Torque App
SCT X3 Spartan Hyrbid Race Tune
ARP Head Studs
Aftermarket degass cap
Cowl hood (not functional)
Atlas 80 PHP FICM tune
Rebuilt FICM thanks to FICMRepair.com!
Rancho RS9000X front shocks
MoserJR82 is offline
post #4 of 13 Old 08-27-2013, 11:41 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Don't get your trans fluid completely flushed unless you change the trans oil religiously! If you have even the slightest wear on the clutch disc, the old fluid will have that material in it allowing your clutches to preform as normal… but if you replace with 100% new fluid the clutch disc will have a slight gap(if slightly worn) inbetween each of them and new fluid will be thinner allowing the clutches to slip and eventually wear out completely.
Just drop the pan and replace the fluid that comes out… and the filters.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 13 Old 08-27-2013, 06:18 PM
JustinOOO9's Avatar
Quoted: 419 Post(s)
Garage
get your filters and fluid from http://www.dieselfiltersonline.com/ and order your internal/external and 10 qrts of mercon lv they have best price i've ever seen. they sell the mercon lv for under $6 a qrt.... under $115.00 including shipping if your not overseas etc...
drain your oil
remove pan, 10mm bolts, you'll need a swivel-head near the cross member
inspect pan
remove and clean magnet
clean pan
replace magnet
(gasket is reusable if not cracked)
replace external filter
replace internal filter
bolt back up snugly but don't crank it
add 8 qrts of fluid through trans dipstick hole in engine bay
start truck and shift to neutral for few mins
turn off truck
check and or add fluid
take about 35 min if your ocd about cleaning everything
there might of been a step missed but you get the idea how easy and much cheaper to do yourself. plus you know it's done right and don't have to worry about a tech. having a bad day on your truck
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes,
currently-1999 F250 SBRB 4X4 First 7.3, 6.0 trans cooler made my muffler fall off
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #6 of 13 Old 08-27-2013, 08:43 PM
Quoted: 8 Post(s)
Agreed ^, its very simple and you get the satisfaction of... A: doing it yourself and B: knowing it was done and done right!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 13 Old 08-27-2013, 08:48 PM
ZMANN's Avatar
Quoted: 1344 Post(s)
your shops stating they can override the bypass bypass is bull **** IMHO
if not this is breaking news
the whole reason for the heated flush is for vehicles just like the 5r with the internal regulation
I hope Mark chimes in because I have even mentioned I wish you could override the bypass to Him
to Him
We Miss you Ronnie
ZMANN is online now
post #8 of 13 Old 09-08-2013, 06:02 AM
You guys have to use mercon sp. If you Dont it can eat up your trans solenoids and cause issues. Mercon sp is what our 5r110s call for and to my experience is motor craft specific!!
Late '04 F350 6.0, studded, 4" exhaust, intake and programmed
ford350f7 is offline
post #9 of 13 Old 09-08-2013, 01:27 PM
Quoted: 8 Post(s)
Mercon LV is backwards compatible with Mercon sp... Mercon sp is just a little harder to get a hold of depending on location.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #10 of 13 Old 09-08-2013, 03:20 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Just drop the pan and change the filters. I have also run Mercon SP for 15k miles and it shifts beautifully
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
