tranny or fuel problem? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-22-2013, 04:34 PM Thread Starter
Recently bought a 04 6.0. The water fuel light was on when I got it so i drained the water and changed out the fuel filters. I have a banks 6 tunner and it was turned up to 4 and did fine until i changed the filters. I went into 1st and then hesitated before going into 2nd. I let off it then it shifted into 2nd. So I turned the banks down to 3 and the truck ran fine just lost some of that pep. So Friday I turned it back up to 4 and then it skipped a whole lot and by the time I got to the end of my road it skipped and cut off. I was thinking that it was the fuel pump b/c I had a gasser chevy and it acted the same way when it was the fuel pump going bad. I am very green to a diesel and have been looking for someone local but everybody knows a guy who knows a guy deal.
04greyghost is offline
post #2 of 2 Old 08-11-2013, 05:51 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
Low fuel pressure and bad filters will destroy injectors in these engines. Get a fuel pressure gauge, 45 psi is minimum at idle and wot. Idealy you want 65 psi. Only use motorcraft filters
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
