5R110 same in truck and van? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-13-2013, 03:27 PM Thread Starter
Quick question can't find answer anywhere. Is the 5r110 the same in say an E450 as it is in the superduty? Torque convertor and all? Difference between ones from gas to Diesel engines too? Thanks
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #2 of 6 Old 07-14-2013, 11:47 AM Thread Starter
Nobody has any thoughts on this?
Amfw119 is offline
post #3 of 6 Old 07-14-2013, 11:49 AM
theplumbingmedic's Avatar
I have thoughts but no educated answers . Bump for ya though
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #4 of 6 Old 07-25-2013, 10:00 PM Thread Starter
Surely with all the plethora of knowledge on this site some one must have the answers I seek! Lol
Amfw119 is offline
post #5 of 6 Old 08-09-2013, 04:23 PM
the 5r110's are pretty universal for the 6.0's they routed the cooler lines different on vans and IIRC they had a fuky parking brake or something on the tail.
But the gasers have a tiny bit different bolt pattern and different internals.
As far as looking for a replacement, the tail housings and output shafts swap out from the rear, so no gutting to convert a 2wd to 4wd.
tommymacher is offline
post #6 of 6 Old 08-10-2013, 11:18 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
The trans is the same behind the 6.4 also... The 6.4 just has two more tq converter bolts and the guts are stronger. You probably would have more reposnses in the general 6.0 discussion compared to the transient problem are. Are you asking because you can get a e-series 5r110 for cheap?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
