Should I replace my fluid if... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-07-2013, 10:20 AM Thread Starter
I have an 05 super duty with 200,000 miles. Transmission seems to be shifting fine no problems, but I have never change the transmission fluid or filters. My local shop tells me to just change the filters and not the fluid, because of the detergents in the new fluid it will cause the clutches to start slipping. Any truth to this?
afterall is offline
post #2 of 12 Old 07-07-2013, 01:27 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Has the fluid ever been changed, or just not by you? If it has never been changed I would not recommend doing a flush. If I were you I would just change filters and drain the fluid from the pan(which you would have to do anyway in order to be able to change the internal pan filter) instead of replacing all of the fluid. From what I have learned, what causes slippage is when you flush a transmission that hasn't had fluid changed for a very long time. The problem with that is your trans gets used to the clutch material in the old fluid and when you replace the old fluid with new fluid you end up losing all of the clutch material that your trans is used to thus causing slippage. Someone please correct me if I am wrong here. When you just do a drain and refill you only drain about 8 or 9 quarts of fluid instead of the entire 18 that the system holds because some will be left in the torque converter. I just drained and refilled mine about 2 weeks ago with mercon sp and it shifts remarkably better. Like you I didn't know when the fluid was last changed because I got it with 124,000 miles on it. just my
Looks like I got way off track to your original question but I don't know about the detergents.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is online now
post #3 of 12 Old 07-07-2013, 04:02 PM Thread Starter
I went ahead pulled the pan off save the old fluid in a clean drain pan. The fluid was a little dark with no metal shavings in either filter. Now the delema, do I put the old fluid back in or 8 new quarts?
afterall is offline
post #4 of 12 Old 07-07-2013, 04:13 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
I don't think I've ever heard of that. I change my trans fluid and filters every 30k (I'm a little overdue, I'm at 93k) hopefully one of the guys who knows about these trans. will chime in here soon.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #5 of 12 Old 07-07-2013, 04:47 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i would add the 8 new quarts the flushes break gunk loose because they come with cleaners they are forced through and then forced back out with new fluid and push the loose clutch materials out from in between the clutches that is loose and floating in there out. dropping the pan will not push that old clutch material out. or fill with cleaners that break loose all the gunk. just change the filters and go with it.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #6 of 12 Old 07-08-2013, 08:46 AM
I'll throw in my 2cent experience. I was just at the dealer last week to do an inspection on a truck I bought. There were three shop techs there standing around so I just started to pick their brain a bit. I was asking them the reliability of the tranny in my 05 f250 and about a leak I saw between the trans pan and the engine pan. In conversation I asked them about what trans fluid to use (merc 5), at that point I asked them about doing a flush because I have heard bad things about it. The concensus among these three was that they have never heard or have seen anyone have an issue post flush. Now take that with a grain of salt, but that is the feed back they have given.
IMO I would add new fluid, I have never heard of putting old fluid back into the trans. I know that the darkness of the fluid and burn smell is due to the chemical composition changing due to heat and contaminates. When the fluid heats it loses some of its intended property. I would add fresh. Hope that helps.
Seattle60 is offline
post #7 of 12 Old 07-08-2013, 09:25 AM
ZMANN's Avatar
Quoted: 1595 Post(s)
they suggested Merc V in a 5r so they are idiots IMHO
A hot flush as required for a 5r to get the cooler bypass open is nothing more than a machine that heats the fluid Merc sp/lv for a 5r and as it intercepts and discards the old fluid it injects new fluid at the same rate and pressure as the transmission would subject itself to anyway
the old dirty fluid holding grit and keeping the clutches engaged ? IDK
We Miss you Ronnie
ZMANN is online now
post #8 of 12 Old 07-08-2013, 11:35 AM
ZMann, what do you suggest for the fluid type?
Regarding the fluid change, does one need to do a heated flush or can I just drop pan, filter change, refill to correct level (Knowing that this method doesn't remove all fluid.)
post #9 of 12 Old 07-08-2013, 12:49 PM
Quoted: 7 Post(s)
it needs to be mercon sp or mercon lv for the 5r110
post #10 of 12 Old 07-08-2013, 04:10 PM Thread Starter
OK, I'm going against my judgement and change the filters and add 8 Quarts of mercon sp or the lv which ever my local ford dealership sales. I am also in the process of replacing my egr and oil cooler, so I'll let you all know how it turns out. Thanks alot
afterall is offline
