trans filter replacement procedure? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-01-2013, 01:45 AM Thread Starter
have a 05, 4x4 with auto tranny,want to change the filter that is on the right front frame rail,it looks to have a large nut that you turn out to remove the filter housing,it looks a little crusty on the casing,is there a danger of the housing falling apart,or the nut snapping off?Havent tried it yet to see if it will move,i should be able to just change the filter in it right?.sorry for the stupid question,but don't want to get in over my head on something that I think should be a simple job.Tranny seems to shift fine,just want to try and remove some potential dirt?. Thanks Harvey
Dark Satin 05 is offline
post #2 of 3 Old 07-01-2013, 03:05 AM
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
this should help:
https://www.youtube.com/watch?v=j1MR2uxqDS0
pretty simple job. however I would not use air tools on the pan bolts aluminum sucks if stripped and for a few extra minutes with a hand ratchet I'll deal with it.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 3 Old 07-01-2013, 10:49 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
This is what's needed:
I listen to BTS..never flush..drop the pan change the filters and add fluid every 30k. If you have a pre '08 replace the pan and stupid screen with a real filter and the '08 up pan.
Should cost less than $150
Filter #8C3Z7A098D
Pan #8C3Z7A194B
CT Performance, Inc. is offline
