trans trouble - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-10-2013, 03:36 AM Thread Starter
svt28640's Avatar
trans trouble
Have an 04 f350, egr delete an sct. When driving the trans will randomly slip. Usually about 40-45 mph. It does it weather driving hard or normal. Just like it were in nuetral, With snap on scan tool, when it happens line psi goes completely to zero. There is no trans codes, od light doesnt flash, fluid is full clean an doesnt smell burnt. Could this be a solenoid issue?
boost, pyro, egt, an fuel psi gauges, fass 150 55psi, fuel tank sump, regulated return, fuel bowl delete, Terminator t500, swamps gen3, irate wastegated t4 kit, billet s475, 400cc400%, fluidamper, swamps girdle, block filled, manley h beam rods, mhale cut/coated pistons, gear heads stage 2 sled series cam, ported an polished heads, fire rings, h11 head studs, swamps springs, swamps push rods, php hydra, precision convertor, suncoast internals, billet shafts, bts valvebody, detroit truetrac.
svt28640 is offline
post #2 of 4 Old 09-24-2013, 09:42 AM
ymraspc's Avatar
Send a message via Yahoo to ymraspc
I would also like to know the answer to this, since mine almost does the same thing. Doesnt seem to me like theres many people on here to help though, as I have posted for the last few days and had no response. Help would be great.
Wifes ride 2006 Crew Cab F350
With Rancho Lift Kit and 35X12.50R18 Toyo Open Country MTs
'01 2500 White,EC, LWB, 272k...HX40 Turbo, DD-2 injectors, BHAF, Holley Black Label Fuel Pump, Vulcan Big Line Kit, Suncoast Valvebody, 4" exhaust, egt gauge, boost gauge, trans temp gauge on pillar mount, fuel press gauge, TST PowerMax3, Silencer Ring MIA
Sold to move to England in 2010
ymraspc is offline
post #3 of 4 Old 12-15-2013, 06:57 PM
pleonard's Avatar
Subscribed .. same issue
pleonard is offline
post #4 of 4 Old 02-01-2014, 03:43 PM
I am also having the same issue with my 04
chris1106 is offline
