Weird humming sound - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-09-2013, 05:51 AM Thread Starter
Weird humming sound
So I have a 2004 f350 and when going down the highway between the speeds of 75mph and 85mph there is what sounds like a humming sound coming from either the motor or the tranny. If I let off the gas it goes away instantly. It doesn't do it any at any other speed, the faster the rpm the louder it is but only between 75mph and 85mph when I hit 85mph it magically goes away. It's really got me perplexed as to what could be causing it. Any advice or info would be greatly appreciated. For what it's worth the truck only has 103,000 on it.
stottman is offline
post #2 of 7 Old 06-09-2013, 10:52 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1741 Post(s)
Feedback Score: 4 reviews
carrier bearing on the driveshaft?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 7 Old 06-23-2013, 04:01 AM Thread Starter
So I checked the carrier bearing and it was shot, replaced it and the sound is still there. Any other suggestions, thanks
stottman is offline
post #4 of 7 Old 06-23-2013, 04:37 AM
Quoted: 782 Post(s)
If your carrier was shot at 103k you may want to go ahead and do u-joints and get it rebalanced. They may be not be any play, but maybe one is starting to seize. Sometimes you could have just a little imbalance and vibrations, at times, can come in at different harmonics. Like you mention at different speeds it comes and goes. Fwiw stick with OEM Spicer u-joints. Your in the same boat I am with a cclb so were stuck with a 2 piece drive shaft.
Corey@CNCFAB is offline
post #5 of 7 Old 06-29-2013, 03:29 AM
mustangmike6996's Avatar
This...
Those vibrations can cause a hum noise
mustangmike6996 is offline
post #6 of 7 Old 07-03-2015, 07:02 AM
Quoted: 13 Post(s)
I have kind of the same issue in a 2004 F-250. It happens as soon as it shifts into OD and continues until I let off of it or stop, then as soon as it hits OD, it starts again. I just got the truck yesterday, and have to work all weekend, so can't check it right away. Could this be the same thing, or a tranny issue?
Sdwyer41 is offline
post #7 of 7 Old 08-27-2015, 06:44 AM
Quoted: 13 Post(s)
Turns out, the right front hub was frozen in the locked position, and there was a bad U joint on the front drive shaft. The front drive shaft spinning, even though it wasn't under power was enough to cause a bad vibration.
2004 F250 XLT 4X4 ECSB
Modifications: Dents, Scratches, Rust.
EGR Delete.
Sinster Diesel Oil Cooler.
Sdwyer41 is offline
