Thoughts on this issue with my 06 - Ford Powerstroke Diesel Forum
post #1 of 29 Old 05-27-2013, 08:55 AM Thread Starter
Galaxie's Avatar
I wasn't towing or hauling anything major. Just a normal drive. All of a sudden it started shifting harder than normal and a very bad 3/5 flair. So I pulled over and put my stock tune back on. Still the same traits. It even feels like its dragging sometimes when I am off the throttle at low speeds. So quick, hard shifting. And shift flair. Not the weird shifting doesn't happen WOT. It shifts great wot. I didn't do WOT for 3/4 because I didn't want a major fair to jack anything up.
So thoughts? Solenoid?
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #2 of 29 Old 05-27-2013, 09:00 AM
My first stop would be fluid and BOTH filters. It could be a sticky solenoid.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 29 Old 05-27-2013, 05:21 PM Thread Starter
Galaxie's Avatar
Im thinking about maybe starting with the solenoids.
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #4 of 29 Old 05-27-2013, 05:25 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Sounds like you have a solenoid issue. It's applying 2 gears at once.
dhanna6powerstroke is offline
post #5 of 29 Old 05-27-2013, 07:42 PM
turbotibbo's Avatar
the first thing I would do is disconnect both battires for a while and do a trans relearn . some times these trans learn them selves in to a hole . if that don't work get a modded direct clutch solenoid and new filter and fluid .... go from there
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #6 of 29 Old 05-28-2013, 03:52 AM Thread Starter
Galaxie's Avatar
Thanks guys!!!!
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #7 of 29 Old 05-28-2013, 03:55 AM Thread Starter
Galaxie's Avatar
Im going to do the batteries tonight....driving gasser today for work. What solenoids do you think this is? Are there part numbers, multiple, upgraded (so the fair goes away for good).
I will research but I know a lot of you have been into this before.
Thanks all!
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #8 of 29 Old 05-28-2013, 09:29 AM
The solenoids all look the same, but they have different locking faces to prevent stuffing the wrong solenoid in the hole.
If I'm not mistaken, the direct clutch solenoid (maybe direct drive clutch solenoid) is located in the center of the back of 3 solenoids. There are a total of 7 if you have never paid attentoin to the valve body. Breaking the plastic on the wire harness is supposed to be the biggest concern when removing solenoids. I would think that some 00 steel wool or some super fine wet dry would be enough to clean the chaft of the solenoid.
As long as you have the pan off, may as well do the pan filter and the frame rail filter.
Karls03 is offline
post #9 of 29 Old 05-28-2013, 09:58 AM Thread Starter
Galaxie's Avatar
Thanks. Is there a good place to get solenoids? And does it seem that this problem is really isolated down to the direct clutch solenoid?
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #10 of 29 Old 05-28-2013, 10:13 AM Thread Starter
Galaxie's Avatar
For example.... what are the chances that this is what I need?
Ford 5R110 Transmission Direct Solenoid | MTS Diesel Truck Parts
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
