p0730 p2703??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-10-2013, 04:55 PM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
p0730 p2703???
so my trannies been acting up for a few months. i drained the fluid, changed both filters a couple months back. A couple days later i realized i misread the manual and put Mercon V in it. so i parked it and decided to have it flushed. the guy did the flush, test drove it seemed fine, so i picked it up. this was about a month ago. A couple days ago it started to shift funny, so today when i got to work i disconnected the batteries to let the tranny relearn.
driving home from work, on the ramp getting on the freeway, it shifted from 4th to 5th, big clunk/bang, then back to 4th with locked up TC. it stayed there and i drove it home. Checked DTC
P2703 Trans Friction Element D Apply Time Range/Ref
P0730 Incorrect gear ratio
I havent changed anything, so i dont understand P0730
And i dont know what P2703 means...
ive been thinking the trannie is toast and needs a rebuild. Am i correct??? thanks...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is online now
post #2 of 4 Old 05-10-2013, 05:51 PM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
Oh, I just remembered, when in backing up, it shutters...
2003 F-350 6.0L.
Leveling kit
Airaid intake
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
Fog light mod
Harpoon mod
Injectors 155cc
post #3 of 4 Old 05-14-2013, 02:53 PM
The 7th item down on your signature is why, Edge Juice blah blah tranny eater! I've been there, used that POS, got the same codes, bought another transmission. When I drained my fluid, it was black and had chunks that looked like coffee grounds, that was what was left of my clutches. Make sure that it ou change your own transmission to blow the lines out BOTH ways to ensure there is no garbage in the lines. We took the fwd filter out and used that as a "collection point" to check our progress.
It's pretty much in it's final throes. My transmission's last "trick" was uncommanded TC unlock, RPM spike, then lock back up.
By the way, Edge only counts the shift EVENT not the GEAR. Long story short, these transmissions shift 1,2,3,5,6, TC lock. You will never see 4th and 5th used back to back because the ratios are 1.09:1 4th and 1:1 5th. The shifts are accomplished by using OD with the other gears. Think of it like an old C-6 and a Gear Vendors overdrive unit.
1st 1st______3.11
2nd 1stOD___2.20
3rd 2nd_____1.54
4th 2ndOD__1.09
5th 3rd_____1.00
6th 3rdOD___0.71
This is just the basics, but that's how it works, 4th gear is ONLY called "mystery gear" by those who don't know how the 5r110 really works.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 4 Old 05-14-2013, 04:06 PM Thread Starter
asian195's Avatar
Quoted: 2 Post(s)
I've learned a lot about the tuners and such. I'm going to take the edge off and sell it on eBay, that should cover the egt expansion for my insight. Then eventually get a sct with custom mileage tune and trans tune.
So my insight always says, 1-2-3-4-5. I always thought it was, 1-2-3-5-6. But got confused with the insight. I thought my truck was never going into 6th, so your explanation makes more sense, thanks.
And idea who has good pricing on trans? So far no matter what I do, local rebuild, order one online, it's coming up to around 5k with shipping. Thanks
2003 F-350 6.0L.
Leveling kit
Airaid intake
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
Fog light mod
Harpoon mod
Injectors 155cc
